Intercooler Project
This is a sticky topic.
  • martinjs
    • 3205
    Intercooler Project
    heres a few pics of the i/c im installing, its quite large but will just fit without chopping the bumper.
  • martinjs
    • 3205
    The only problem is finding/making a x-member to suit, ive tried one from a 9020v but it extends too far fron the mounting face (about 150mm, plus the 70mm thicknoss of the i/c is too much)
    so got one from a coupe V6 which is a lot flatter and sits a lot lower.
    • martinjs
      • 3205
      So now the problem is the snub mount position, but one from a urs4 should solve this as its x-member sits in the same position.
      So i'll need to remove my air con as it is mounted in the same place as the urs4 snub,it didnt work properly anyway, :wacked:
      heres a pic from behind the bumper, just fits, dont see why it shouldnt work,
      and it was cheaper than an RS2 intercooler, i know the intake tract will be a tad longer but will go perfectly with a wagner style inlet manifold
      • SteveH
        • 4460
        That looks BIG Good luck fitting it
        91 Modded 3B
        14 A6 Avant Black Edition
        • Mark Halligan
          • 2001
          Martin,
          that looks the 'nuts' m8, nice one .
          Mark.
          Mark - Modded
          • martinjs
            • 3205
            now that i'll be fitting the Rs2 bumper , should give me a bit more space.
            may not have it on for the meet, but if i get all the bits together by then maybe can fit it at gregs, have sod all time in the week to work on the car:wacked:
            • Stick Insect
              • Dec 2003
              • 2338
              Martin, I'm sure that I could fabricate one for you,
              I don't know how we could do it. If you made it out of wood I could make a copy in steel?
              If you pop over I could whip one up. Surrey to Cheshire is a short run in an S2
              Have a think.
              I'm making some sheet steel seat bases 1950's 'd' type Vincent Motorcycles at the moment.
              David
              • martinjs
                • 3205
                David, the ideal solution would be a x-member (like in the second pic) that is flat right across (without the 45 degree angles at each end) that way i can keep the original snub mount position, and generally be a lot easier to sort out.
                i could take some measurements from the 90 20v x-member i have,
                i may be in touch then m8.
                cheers
                martin
                  Martin,
                  Could you not just cut the mounts off the original one you have there, after taking some measurements from it this is, and weld a length of box section with the mounts at either end?
                  • Stick Insect
                    • Dec 2003
                    • 2338
                    Martin,
                    Would you like it with or without the mounting bricks?
                    Let me know what you want
                    Draw a diagram and I will make it for you. I can make it without drilling all the holes.
                    It would be in steel, I have not got TIG yet to do alloy as I dont need it and I don't have the space.....
                    D.
                    • martinjs
                      • 3205
                      I think thats the best way greg, i'll take it to bits again and get some dimensions david, and mail you what i come up with,
                      martin
                      • Jeffer
                        • 2057
                        Hi Martin,
                        Looks great that IC.
                        Did it fit ok behind the rs2 bumper?
                        Do you have any dimensions of the IC?
                        Would really help if I have some dimensions.
                        RS2 Black - stock 315 HP
                        RS2 RS blau - stock 315 HP
                        Sport Quattro - 1005 HP
                        High Octane website
                        • Stick Insect
                          • Dec 2003
                          • 2338
                          Jeffer,
                          See this thread
                          After the Standard S2 bumper had been cut a little it went on.
                          Martin has the sizes
                          Fitted behind the grille photo for your information.
                          It went in OK but was a tight fit!
                          David
                          • martinjs
                            • 3205
                            Jeffer,
                            im still using the original bumper at the moment
                            core size is 600mm x 300mm x 76mm..overall width is about 750mm
                            IMO 300mm is the max height you will be able to fit behind the stock bumper, havent got round to repairing the RS2 one i have yet suppose there may be a little more room using that.
                            martin
                            • Jeffer
                              • 2057
                              Ok, what do you think will fit the rs2 bumper. Think 40 cm will fit? The bigger the better, at least that's what my girlfriend says
                              thanks
                              High Octane website
