Project: Engine Build for beginners.
  • Acidburn
    • 13459
    Originally posted by Flat on my back
    this project is now on hold...
    Now looking for a new job...
    Sorry to hear this mate
    and was going to ask if you was around friday when a few of us are going to be working on the quattro saloons at the lockup could have sorted your bits out.
    • Flat on my back
      • Jan 2007
      • 2449
      If you need a hand just say...tools in the back and leave straight from work...not redundant yet, but imminent!
      PM me if ya need a hand, it'll keep my mind off things.
      Carlos.
      • Flat on my back
        • Jan 2007
        • 2449
        In the light of all things...
        I have raised my middle finger and declared stuff the recession...up the revolution...
        If the rest of the world is in debt, i'm joining them...
        Bry, you there...tis for you.
        LS2 coils from here
        http://cgi.ebay.com/ws/eBayISAPI.dll...m=130196798963
        and from here.
        http://cgi.ebay.co.uk/ws/eBayISAPI.d...B:EOIBSA:UK:11
        Must learn to do that linky thing better...
        Carlos.
        • Knight Rider S4
          • 3541
          Hi Carlos
          Do you have a how to on the making of the harness for linking the coils to the main block connectors on the bulkhead
          Steve
          93 S2 Avant Parting
          91 URQ RR
          02 A4 tdi Avant
          • Flat on my back
            • Jan 2007
            • 2449
            Er ...no...er...
            Haven't decided on my loom or ecu at the moment...
            You should only need to get connectors and bodies to mate up to the original loom, the last link was the coil connectors plus wiring...i'm hoping...running abit blind as i dont have an aby to scrutinize...
            s2central should be able to help with parts as he has been doing a lot of searching lately on Bosch connecors and crimp terminals.
            HTH...
            Little bit more info here.
            Carlos.
            • merlin's S4
              • Jan 2005
              • 1539
              Originally posted by Knight Rider S4
              Hi Carlos
              Steve
              Look up the guides for the 1.8T coilpack conversion. Most of the wiring details are there, you just need to change the coilpack connector for the LS2 version.
              • fastscirocco
                • Dec 2007
                • 34
                You may find the following info helpful:
                Find information, resources and relevant links for filesavr.com. This domain may be for sale.
                Here are pics of my D585 coil conversion on a US 95 S6, I didn't want to install the coils using alot of splices so I sourced all new connectors, heat resistant sheathing, etc.
                Next on the agenda is to purchase some cable seperators to keep the spark plug cables neat, and to remove the coils
                from the cover and reinstall the cover.
                I wanted to be able to replace one coil without completely disassembling an entire bracket, here is the bracket I
                came up with.
                It is currently hanging from the strut tie bar, but I am planning on making support brackets that would bolt to the
                firewall via the factory's wireing harness bracket. I should be able to mount a cover on top of this bracket
                (the top mounts would be gone)
                • jade
                  • Jan 2005
                  • 1811
                  #143
                  came up with.
                  Do you have a link on where to get the same coils as you have with heat sink
                  Also info on connectors & terminals
                  Thanks
                  RS 2 580HP
                  • Flat on my back
                    • Jan 2007
                    • 2449
                    Jade.
                    Just for you, the part no.s are in here. Good read too. Do a search on the part no. and they'll probably spring up on the 'bay somewhere.
                    EFI, Fuel Injection, Auto, automotive, car, TPI, computation, ECU, MegaSquirt, GPIO, MicroSquirt, Sequencer, stim, MegaShift, MShift, DIY, transmission, 4L60E, 4L80E, controller, shifter
                    Carlos.
                    • fastscirocco
                      • Dec 2007
                      • 34
                      LS2 coils from here
                      and from here.
                      Looks like you are planning on using the Delphi D581 coils, highly recommend
                      you use the Delphi D585 coils instead, they use the same connector but are
                      a more powerful longer life coil.
                      Chris
                      • fastscirocco
                        • Dec 2007
                        • 34
                        Thanks
                        The coils are for GM Yukons and other cars, they are Delphi D585 coils otherwise
                        known as LS2 coils. The seller I purchased from is out of them but you can get
                        them other places.
                        forum meber Marc Swanson - a4kquattro. owner of the V8 tt coupe, FEMS guru, owns http://www.efiexpress.com/catalog/ he doesn't list the coils as a seperate item, but I know that he will.
                        Also he has a kit which includes a wiring harness making it plug n play.
                        http://www.efiexpress.com/catalog/pr...products_id=18
                        I recommend you give him a shout.
                        * edited to fix link
                        • jade
                          • Jan 2005
                          • 1811
                          #147
                          This looks good
                          I might give it ago if in stock soon
                          RS 2 580HP
                          • fastscirocco
                            • Dec 2007
                            • 34
                            This looks good
                            He'll have it soon, if it's what you want I'd suggest you contact him and get
                            your order in, he's been selling alot of them lately.
                            HTH
                            Chris
                            PS No affiliation to Marc, just like his products/service.
                            • jade
                              • Jan 2005
                              • 1811
                              #149
                              Yes I emailed him
                              RS 2 580HP
                              • Flat on my back
                                • Jan 2007
                                • 2449
                                Since i've joined the masses of the 'great unwashed'...
                                A little more work has got done:-
                                De-flashed the block, drilled the oil drain and had the bores checked (minimal wear of 1 thou. good to go on this block).
                                Custom pistons are being worked on wth Aelreds help.
                                25MM cam pulley has been modded and bought myself a special cam sensor which should be fully compatible with the ecu signal.
                                Next job is to check the bore clearance with the 92.8 crank and the Scat rods.
                                Carlos.
