Mount machinined for the GSf tensioner, had to be fitted minus the plastic 'wheel'...hope the serrations dont mark the belt. Fits quite nicely and has just enough adjustment.
Carlos, i'm probaly being dumb, but why did you go to all the trouble of trying to mount the ABY tensioner, and use the GSF sourced one?
whats wrong with the 7A / 3B method on this build?
Sorry to hijack your thread, but i'm trying to fit a cooler housing to a 7A block. That massive threaded bit in the middle, does that just screw out? How did you get it out? Then I need to find two stubs and push them in after the housing is in place?
It looks obvious from your post but I just wanted to double check,
That would be dead useful mate, I'm just trying to source all the bits still. Is it possible the large threaded bit comes out the housing aswell, that would be far easier, then I could just keep the one in the block. On your 7A, are you planning to just block off the seperate oil feed on the housing which i'm guessing is for the turbo?
