Project: Engine Build for beginners.
  • Flat on my back
    • Jan 2007
    • 2449
    How heavy...
    For those weight consious ones the bare block in the previous pics came in at 46.5 kg,
    and
    the IL5 92.8mm crank i have was 20kg.
    Carlos.
    • Flat on my back
      • Jan 2007
      • 2449
      issue 2 of the pdf
      Slightly tweeked after checking against the actual tensioner holes.
      Carlos.
      • Flat on my back
        • Jan 2007
        • 2449
        7A block thickness...
        this is the position of the hole nearest the water pump...
        Carlos.
        • Flat on my back
          • Jan 2007
          • 2449
          Water manifold template.
          Here.
          Carlos.
          • Flat on my back
            • Jan 2007
            • 2449
            Plan 'B'...
            The 'plugs'...
            Carlos.
              #81
              So Carlos... This is good, when you drill thru for each big plug, it would be cool to take some depth measurements so we know how much/little material is there - on the 7A block at least.
                #82
                Explain the crank, rod & piston thing to me - my brain isn't working today - how do you get 2.5L on that setup ?
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Darn...
                  Think i'll have to sacrifice my spare block for this, to be on the safe side.
                  Results to follow...
                  Carlos.
                  • Flat on my back
                    • Jan 2007
                    • 2449
                    Eh...
                    Nope, only going for the 92.8mm crank, 144mm rods and off the shelf Wossner pistons from a VW block...which matches crank stroke, rod lenght and a deck height of 220mm.
                    Done deal.
                    HTH
                    Carlos.
                    • Flat on my back
                      • Jan 2007
                      • 2449
                      Part no. for the tensioner/wheel.
                      054 109 479 A
                      Carlos.
                      • Flat on my back
                        • Jan 2007
                        • 2449
                        Warning-exhaust Many Porn.
                        Dribble...
                        Carlos.
                        • Flat on my back
                          • Jan 2007
                          • 2449
                          A few more differences on the 7A block...
                          the oil filter fitting needs to have 2 guides fitted and the short stubby threaded piece removed so the new filter housing can be fitted. I used 2 M5 X 12MM spirol pins tapped in to leave 5MM showing and the stubby thread came ut with some pipe grips.
                          Carlos.
                          • Flat on my back
                            • Jan 2007
                            • 2449
                            Bad news folks...
                            Trying to attach the ABY tensioner to a 7A block will be mighty tricky...not really enough material in the block where the 3 holes are drilled to make a good water tight seal...but there is plan 'C'...
                            Carlos.
                            • Flat on my back
                              • Jan 2007
                              • 2449
                              This is the tensioner from a late v6 80, bolted into the very rhs top hole of the block.
                              It will need a 'stand-off' pilllar to clear the pump and once i've fitted the rest of the belt parts i can check that correct tensioning is achievable.
                              Anyone borrow me an ABY cambelt for a wee while...still trying to source my 25mm...
                              Carlos.
                                Yeh i've got an old one you can borrow.
