SWB Quattro Project
  • terrybullwon
    replied
    Air jacks?
  • afterburner
    replied
    What's your battery? Try getting a LiPoFe battery like this one http://www.hobbyking.com/hobbyking/s...ePo4_Pack.html
    It's light, small and can be connected on will when you know that your voltage has dropped. It has enough current rating to actually start your car also and be used as the primary battery, so it should be enough to boost your electrical system during runs.
  • G60Rallye
    replied
    There is no issue with the alternator off the prop when the car is constantly running say on a track. There is no belt slip or anything like that, I have it running on a multi ribbed belt.
    The problem is when the car has been warmed up in the pits to get it up to temp then having to que up and eventually start the car up again. By the time its setting off the volts are down to 10 and the alternator in 11 seconds cant get the charge back in against the car running flat out. The ecu has a compensation table for voltage and under 10 volts its seriously unhappy which is what it was dropping to in the runs.
  • djh
    replied
    i'd have thought the voltage drop when the car is sitting still
    replied
    what is the actual issue with the alternator driven off the prop Hamish?
    Is it the V-belt not able to keep up and slip? or does the mount flex losing belt tension or is it a pulley size issue and over or under speeding the alternator? Audi sport made it work so I am sure it is nothing fundamental holding you back - maybe a custom prop pulley and use an ABY or AAN poly-V on the alternator?
  • G60Rallye
    replied
    Bit of an over due update. The car went up to a mates to get the filler work done.
    Ran out of time to get the shell painted before inters so got my mate to primer the shell at his house so I could use the car:
    Panels came back from being painted and I got it built back together ready for inters:
    Welded a plate onto the steering column to mount the dash and its buttons:
    All working which is a big difference to the old dash!
    I got the car to inters after a full weeks work. It was lacking some bits of trim and grills etc, but it was good to use it. First run on Saturday it went off the line well but then in 3rd and 4th it had a missfire. Then on the return road I could hear a clunking from the rear end so I suspected a shaft or diff. Got it back to the pits and it was just the rear diff lock not fully disengaged (I had forgot to lock it). Whilst under there I could see that the rear tie rods had hit the anti roll bar on launch so it was off with the roll bar for the weekend.
    I did further runs at the weekend but all were with the same issue in 3rd and 4th. Tried a new set of plugs, and got hold of a new set of coil packs from the guys at PSI who did a cracking deal for me so thanks to them. In the end with some help from Keith Murray of Dialynx we discovered the issue was low voltage causing the ecu all sorts of issues with the injectors and coils. The rear alternator just couldn't get the voltage up in time so its back to the drawing borad on that one. A big thanks to Keith Murray who was a great help all weekend!
    The car managed to do an 11.5 at 123 which is 10mph slower than normal. Also managed a few other 11 second runs at around 110 due to lifting in 3rd. It was 60 footing in 1.6 range and I am sure it would have run a 10 if the terminals were in the usual 130+ range.
    The only video I can find from the weekend running against a mate in his highly tuned stripped TTRS. Had to lift in 3rd so gave him the win but showed him how to launch!
    So I am going to look at putting the alternator back onto the engine with a ribbed set up to get around it chewing up the v belt. I am also making some new rose jointed rear arms which bolt under the hub pick up to give more clearance for the bladed anti roll bar.
    I have entered ten of the best at Elvington in 2 weeks time so hoping to get some good times out of it there.
  • Qwerty
    replied
    I'll have to just see it another time
    Do you come any further North?
  • G60Rallye
    replied
    No doing GTI International at Shakespeare all weekend sorry.
  • Duffelcoat
    replied
    Originally posted by Qwerty
    I know you said you're going to Gti international but, Any chance you will be at the Retro Car Show at Santa Pod this Sunday?
    Can't wait to get a look at your car in the flesh
    I might be going to the retro car thingy are there many from here going?
    Although I m not sure my car is retro enough, but looks like an interesting event...
  • Qwerty
    replied
  • G60Rallye
    replied
    So restricted sticking with the ur quattro set up. The hubs/ uprights weigh a huge amount and suspension choice is very limited, with home made being a guessing game. I wouldn't get hung up on the sport quattro wishbones. If you want fancy wishbones get the ones from 034 I would bet they are a lot better made than the sport ones.
  • diesel des
    replied
    Is he making these parts again? When I tried to get them 2 months ago he wasn't...
    Sent from my GT-N7105 using Tapatalk 2
  • jsws3
    replied
    Originally posted by niall1
    OK thanks. I have Sport Quattro wishbones etc. underneath and don't want to junk those to move to an S2 setup. I might go with the KW build based on the original struts. I'll let you know how I get on..
    Regards
    Niall
    Bambridge can supply the nursery parts to convert your original suspension to coilovers .
  • niall1
    replied
    Regards
    Niall
  • G60Rallye
    replied
    Its running full S2 running gear now so yeah I did have to change a bit to get them to fit! Its a far better set up than the ur quattro suspension. You dont have to deal with 034, plenty of dealers for KW in this country and you can deal direct like you alredy have.
