My 3B-AAN 400 HP project
  • Pirvu Eugen
    replied
    I changed those too... and i use the caps on the valves to fit them...but is not a must. iff you are carefull will be ok.
    I finished today the engine...removed everithing...cleaned, checked, oiled and installed back. I was really lucky that nothing was affected.
    The head assambled back too...checked..no leaks..hope will stay like this.
    Tommorow i have to install the head back, put the engine on the car and do another test.
  • pasbogdan
    replied
    Nice work at valve lapping/area that closes on the seat.
    Try washing all with powerwasher.You will get all wet but put the washer gun at all oil pasages etc.Aslo crank oil pasges.I use "TRIUMF" and it gets all out.Not friendly with alu.But if water is enough will not get oxide.
    Not nice what you got there,but you only loose a headhasket and lots of labour.What you think of keeping valve seals?When you get them new you use a film or a cap supplied with the seals not to hurt their sealing lip.But when getting valves out?
    Best regards!!
  • Pirvu Eugen
    replied
    Luck was as i have just turned the engine via starter motor to lubricate the engine...never runed the engine. Never thought that the intake was sandblasted.
    The bores are ok...it was just few revolutions using the starter that was all.
    Anyhow..i will remove the pistons and clean everithing.
    I cant imagine iff i saw this in UK...
    I was lucky.
  • Ross
    replied
    Indeed that looks to be the same issue as Sonics build.
    Hopefully you caught it on time, has the engine been running since the rebuild? There are also issues with turbo, oil pump, everything needed removing and cleaning or replacing! Hopefully the bores are not ruined...
    Just make sure theres no chance you still have sand anywhere in that engine when you rebuild it.
    Im never getting anything sand blasted in my engine bay!!
  • Pirvu Eugen
    replied
    I allready bought 2 headgaskets to make another dropping cr one i had and intake manifold gasket plus 2 oil pan gaskets...
    I will remove the pistons too to clean all there...
    OFFF!!!!
  • Pirvu Eugen
    replied
    ... I had to dismantle the engine!!!Luckly it happend here and not in UK at the dyno...
    I wanted to run some oil through the engine and check oil pressure etc at starter speed.
    Filled with oil, turned over...oil pressure at 5 bar...excelent i said...but...i was thinking to check the compression as it is now...
    cilinder 1 and 5 ....3 barthe rest 11 bar...WTF??
    Took the head off and found this...
    The intake manifold was sandblasted at some point and i didint know....i cleaned how well i could, but at nr1 and 5 i couldint reach all i suppose.
    I was more lucky like Sonic with his engine.
  • nemilosu
    replied
    Nice work.
    Do you need a driver ?
  • Pirvu Eugen
    replied
    I saw Jogy's dyno plot with the t34 turbo and internal wastegate and i try to recreate as much as i can that setup. Hope it will be ok...iff suvives Ashford's dyno
  • Kieron20V
    replied
    Originally posted by newsh
    Call me old fashioned but.. er.. where's the wastegate?
    First page says internal wastegate t3/t4 hybrid.
    replied
  • bartolomeus
    replied
    Haha welcome to the forum Tavy!
    We are now waiting for you to buy an S2 so you can be a proper member
  • allcustom
    replied
    stop it you guys i'm blushing
  • bartolomeus
    replied
    Yap that's Tavy's work allright!
  • Pirvu Eugen
    replied
    The welds are nice indeed....there will be a small modification at the tailpipe...as the rear bumper...i think will go a little up from the left side...but Tavy told me that will be an easy fix after i install the bumper in the right position....
    I am happy!
  • LHD_Kid
    replied
    Looking superb!
    The welding looks excellent :-)
