Each end is a new beginning.
  • Skull
    • 3506
    • Country: Slovenia
    #961
    tested a 7,5" 195 45 wheel, looks like this will be the final look
    Audi Quattro WR
    • BLAMM0
      • Aug 2010
      • 337
      • Country: Lithuania
      #962
      simply nice!
      • Bram
        • Aug 2006
        • 2582
        awesome!
        • yavor20v
          • Apr 2006
          • 163
          • Country: Bulgaria
          #964
          Stick to the compi in this thread ,man!
          The oldschool isn't that beauty like the compi!
          • irishs2
            • Apr 2009
            • 2455
            Lovely looking. Not my fav colour though. Also something weird about the front lights and grille.
            Eric
            95 S2 Avant under rebuild.
            • Skull
              • 3506
              • Country: Slovenia
              #966
              yeah but nothing going on on the compi, so...
              Audi Quattro WR
                #967
                Skull,
                Lovely new daily, I know you'll like to improve it further.
                Couple of issues to consider for the car.
                Change the front orange indicators to clear, same "colour" as a later S2 Avant?
                Cover up the chrome inserts on the door handles with a strip of black insulation tape. Worked well on my Mk 1 Golf back in the day. Powder coating in black may work as a permanent solution.
                Use the same tape on the chrome rim on on the bumpers and the grille as well as around the windows to see if you like the GTI effect before putting a more permanent solution in place, to replace the GLS style trim.
                Don't like the wheel arch trims, a step too far.
                Do you have photo of the rear of the car, the interior, and the engine bay ? Keen to see them before you make any changes ?
                In relation to the Compi;
                Do you have the part number for the gearbox "shield" that attaches to the end of the engine undertray on the B4 ?
                Do you have the part number for the red rear light clusters for the B4 ?
                Change the white S8s back to silver ? Post # 863. Don't like the A8 7 spokes. Post # 869.
                Have you got a Neuspeed rear anti roll bar fitted on the rear, well worth doing. BTDT.
                Love the interior. Post # 913. Powder coat the chrome door pulls to RS2 style, it's a great upgrade you'll touch / see all the time, low cost.
                Inspirational engine photo in post # 938.
                In relation to the ability of the ACE engine to rev in posts around 851, consider the following, replace the fuel pump, relay the fuel pump, replace the fuel filter ?
                One of my favourite threads. Keep enjoying both cars and posting updates for the rest of us.
                Kind regards.
                • Skull
                  • 3506
                  • Country: Slovenia
                  #968
                  I have the quad lights in mind, clear indicator in the bumper
                  Well, there is so much chrome on the car, it really feels oldschool, so i think i will add more chrome.
                  Like said, more chrome coming
                  I really like them, and they are easy to fit, so they can be installed/removed easly, no big deal.
                  Do you have photo of the rear of the car, the interior, and the engine bay ? Keen to see them before you make any changes?
                  No changes on this subject, it will stay stock, maybe i will add the stock aux gauges and that`s it.
                  Audi Quattro WR
                  • Skull
                    • 3506
                    • Country: Slovenia
                    #969
                    Do you have the part number for the gearbox "shield" that attaches to the end of the engine undertray on the B4?
                    I will check for the PN, but there may be an issue with overheating, because it is a little strange that those plates were only fitted on diesels.
                    Can you post a photo of what exaclty do you mean?
                    I like them white
                    I have installed the s4 rear arb, that is 15mm thick.
                    Yep, should do this.
                    In relation to the ability of the ACE engine to rev in posts around 851, consider the following, replace the fuel pump, relay the fuel pump, replace the fuel filter?
                    I found the issue, the fuel pressure regulator has a small L shaped pipe, that goes to the airbox. It was cracked, and it was only leaking at high pressure/vacuum. Changed the tube and now it revs to 7400rpm
                    Tnx!
                    Audi Quattro WR
                      #970
                      I will check for the PN, but there may be an issue with overheating, because it is a little strange that those plates were only fitted on diesels. Agreed, you're right, no worries so.
                      Can you post a photo of what exaclty do you mean? The red colour coded rear lights for the Compi as per post # 885.
                      I like them white
                      I have installed the s4 rear arb, that is 15mm thick. Oh yeah, forgot you did, does it need the strengthening bracket that comes with the Newuspeed kit ?
                      I found the issue, the fuel pressure regulator has a small L shaped pipe, that goes to the airbox. It was cracked, and it was only leaking at high pressure/vacuum. Changed the tube and now it revs to 7400rpm At last an inexpensive cure for a B4.
                      Tnx!
                        #971
                        Originally posted by David in Dublin
                        a few possible ideas / annoyances / dilemmas ! ?
                        1. 17 inch Avus wheels with 225/45/17 ?
                        2. Lowering springs - 30 or 40mm drop, but to definitely give the same drop both ends, whatever the drop.
                        3. VW 16 Valve KR engine inlet and exhaust cam?
                        4. Relays for each of the H1 bulbs in the main headlights, with a 15v regulator in the alternator?
                        5. Black alcantera headlining to deal with the standard light coloured headlining? Matching black sun visors?
                        6. Bigger clip-on mirror over standard interior rear view mirror?
                        7. Satin black powder coat the door opening latch on each door?
                        8. Add interior lights to each of the four handles set into grab handle in the roof, if not already in place?
                        9. Aero wipers.
                        10. RS2 Front anti roll bar, whatever uprated one fits a saloon, Neuspeed = Avant, Whiteline = Coupe, Saloon = ?
                        11. Eventually funds permitting, an RS2 leather?
                        12. Assumptions are shocks are RS2 or Konis, all bushes and ball joints perfect or replaced with factory items from say Febi, rear brake calipers upgraded to say fresh Mk 4 Golf ones, and whatever MK 4 or R32 ones can be bolted up to the front end at minimal cost. ( the standard 280mm front brakes are not bad for a standard 140bhp engine ).
                        13. If you want to keep the engine, eventually head work and throttle bodies with cold air ducting, exhaust manifold ( from who ?..... custom made ? ), larger bore stainless exhaust.
                        Not much more after all that ? ?
                        Very fine car BTW, just as it is.
                        Kind regards.
                        Skull, just revelling in the earlier parts of your thread, you done most of what was in this list.
                        kind regards.
                        • Skull
                          • 3506
                          • Country: Slovenia
                          #972
                          fixed all the photos links in the old posts...
                          Audi Quattro WR
                          • Cage
                            • Aug 2011
                            • 3
                            • Country: Russian Federation
                            #973
                            Originally posted by Sküll
                            The upper one is the alfa thing, transparent white window logo, the lower one is the audi one, plastic logo in green plastic. Both buttons are exactly the same (inside and outside), just the window logo is transparent + there is 3mm led in the alfa unit.
                            Hi!
                            It was along time ago, but may be you know the part number of the Alfa one?
                            Thx!
                            • Skull
                              • 3506
                              • Country: Slovenia
                              #974
                              no sorry, i dont know, it was and alfa 155 or 33, they all look the same to me
                              Audi Quattro WR
                              • Cage
                                • Aug 2011
                                • 3
                                #975
                                Ok, will try to search by model.
                                Thanks anyway
