love the oldie! good work!
Each end is a new beginning.
Hello Sküll! You mentioned that you used Audi A4 B5 rear shocks from Bilstein that where for shorter springs so they lifted your rear end. Do you have the exact part number of those shocks?
As far as I can see from the Bilstein catalogue there are 2 types of rear quattro shocks for the A4 - 24-062121 and 24-026215. The first one is in the same as the 80 Quattro Competition one. It's used according to the catalogue from MY 07.2000, so it's in the last B5s.
I guess you used the second part number, which was used before 07.2000, the first B5s. Can you confirm this? I want exactly the one that's for shorter spring, so I can lift my rear end a bit. Thanks!Comment
Hmm, OK, thanks
6214 was the part number for the front Koni shocks that I'm currently using. Will have to find a show which is willing to open new rear shocks for B4 and B5 and compare visually
Thanks!
OK, apparently I was going through Bilstein B6, not B8, that's why I didn't find that exact shock... If I go with it instead of the original Competition rear shocks the rear end will go up according to your experience, am I right?Comment
when i was buying, the b4 quattro avant didnt had its own set of b8, but there was only the a4 b8 available. nowadays it looks like everything is available.
so:
buy a4 B5 quattro rear bilstein B8 dampers, and it will lift the car by 2cm.Audi Quattro WRComment
the works on the oldy are almost completed, it is time to return to the compi...
thought to make a list of things that have been done to the car so far...
OEM black taillights
S2 aux gauges
Bord computer
el. rear windows
3 spoke leather steering wheel
ellipsoid headlights
s2 avant sideskirts
s2 maing gauge with rs2 black rings
headlight washing mech
american middle console
kaw 60/40 springs
A8 middle console switches + taxi switch + funk switch
powerflex bushes allaround
koni adjustable fronts, bilstein b8 rears
racing spoiler pack
5x112 mod
new cv joints allaround
new wheel bearings allaround
every rubber bush new
gearbox mounts new
fox 2,5" catback exhaust
allroad aerowiper kit
new brake lines allaround
rs2 small reds in front 314x30
rs2 door panels with carbon
rs2 front seats, electric and heated
rs2 brake ducts
s4 v8 rear brakes 300x22
moved the battery in the back s2 style
klimatronic AC
cruise control
rs4 15mm rarb
s2 strut bar
5x112 competition wheels
tubular EM
sport cat
hevily modified TB
s2 avant lower door trims
carbon b pillar trims
s4 autodimming mirror
new oe front bumper
new oe front wingsAudi Quattro WRComment
