what is your lamda on those high rpm?
450hp "(NOT)enough power" project
i allways keep the lambda under 0.8 on high boost and high rpm. i mean i allways keep it under 0.8
i run with standard pistons now. i have to save them.
i have lambda program. if i dont push the throttle more than 30%, its try to compensate to 0.97--------------------------------------------------------
Real carbon parts for S2 and RS2. Check Carbondesign on facebookComment
[QUOTE=Bram;413097]its can be normal, if your car maped near to surge line. we ussualy maping on 4th gear. if i doing WOT on 4th gear without surge, its will be surging,if you do the same in 6th. if you map the car 1,5-1.8bar with the same setup, no way to surge.6th gear will always do that,it does surge a bit.Mine does as well.
QUOTE]
Ehm.... well my car does not surge in 5th or 6th gear doing WOT at lower RPM, so I am not sure if it is 'normal' what you describe on your setup. I never experience surge to be hounest with my car--------------------------------------------------------
aronmatic2 : the stock pistons and the rods of the S2 engine (3B,ABY) is forged as a 7A engine (2.3 20V) , isnt it? when i see u runnin H conrods and stock pistons.How much u have run up on these stock pistons?thx for answer...TomAudi Coupe Quattro 2.3 20VComment
OK, that could make sense, as my GT3071R setup is mapped only for 1.7 bar on the lower RPM numbers. Good info Aron. tnxOriginally posted by aronmatic2;
its can be normal, if your car maped near to surge line. we ussualy maping on 4th gear. if i doing WOT on 4th gear without surge, its will be surging,if you do the same in 6th. if you map the car 1,5-1.8bar with the same setup, no way to surge.Comment
we will see, where is the end.
now its stil ok.--------------------------------------------------------
E85 = ethanolAndreas Lundstroem
A4 STCC Avant -04
Audi /S/2/ Sedan -94
prev.
Audi /S/2/ Coupe -91Comment
E85 is 85% Ethanol with 15% fuel mixture, wintertime it's 75% ethanol , its a bio fuel.
Tom: correctly tuned and built that should be no problem with stock pistons! (if you blow the stock pistons with 450hp you will blow the car with JE pistons or CP pistons too)2004 9-5 aero
2009 Subaru Legacy Diesel
1994 Toyota Supra Eurospec 6-spd LHD
3-4 Audis in parts
