450hp "(NOT)enough power" project
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    #241
    Originally posted by prosty
    E85 is 85% Ethanol with 15% fuel mixture, wintertime it's 75% ethanol , its a bio fuel.
    Tom: correctly tuned and built that should be no problem with stock pistons! (if you blow the stock pistons with 450hp you will blow the car with JE pistons or CP pistons too)
    sure, but thats sound nice but worst to do that (correctly tuned) Have u experience with turbocharged 7A engine (2.3 20V) ?
    i think the pistons will be better with lower CR , the original 7A CR is 10,3 :1
    aronmatic2 : sorry for OT
    Audi Coupe Quattro 2.3 20V
      LOL I've just notice the project has been changed from 450 enough power to 450 not enough power!
      Missing that stroker Aron?
      • aronmatic2
        • 2129
        • Country: Hungary
        #243
        yes. i have a plan for winter.
        i need 200 more hp and 200more nm.
        the mods on this winter:
        catcams camshafts
        stronger valve springs
        titan retainers
        mech- lifters
        2.6 stroker engine(tall block)
        special 154mm rods
        coated special race je pistons
        gt35r turbo
        wagner ic system
        electronic throttle
        2 window air conditioner
        4 special drive shafts
        thorsen rear diff
        almost all parts i have, but i dont want to do anything in summer. i am so lazy in this weather.
        Real carbon parts for S2 and RS2. Check Carbondesign on facebook
          catcams camshafts
          titan retainers
          mech- lifters
          special 154mm rods
          gt35r turbo
          wagner ic system
          electronic throttle
          thorsen rear diff
          Nice spec! tell us more about the electronic throttle?
          If your doing 2.6 running 83mm pistons then.
          For you i'd consider knife edging the stroker crank from 22kg to 20 kg same as stock 86.4 crank. I didn't do it as I'm not really bother with it being a street car
          • Bram
            • Aug 2006
            • 2582
            Nice plans Aron. Let's hope the winter comes soon this year, so we can enjoy your project build ASAP
            • aronmatic2
              • 2129
              • Country: Hungary
              #246
              i thinking about rs6 throttle. i have to buy to check, how can i install.
              knife edging? come on jamo. we are not honda tuners. i dont think its a good idea.
              the crank is perfect like original.
              i try to make a better writes and pictures like earlyer.
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                #247
                again!!!!
                it really didnt last long, did it?
                good man Aron! let us know about the 2 way aircon!!!
                  The problem with the stroker 95.5 crank is it stops making power above 6000 rpm, by knife edging to take it to the weight of the 86.4 crank you can theorectically make and hold power to the 7300 red line.
                  This is countered though if you got a stroker you don't need to rev that high when driving in reality
                  • aronmatic2
                    • 2129
                    • Country: Hungary
                    #249
                    i ask my partner. i dont know lots about it.
                    • Billman
                      • 4129
                      #250
                      dont think that the problem with the stroker and the power above 6000 RPM are the 2 kilos more weight. It depends on other design specs as rod length etc
                      Go Holset or Go RS4
                        No it's to do with reciprocal rotating mass of the crank, rod length make no odds as your choice is between 155-159 mm rods and they all give a good ratio.
                        There other factors with piston dwell time and the fact the pistons spend longer at tdc and bdc.
                        Tons of stuff on the net, as I said I wasn't bothered by it as my car is for street not track.
                        • Billman
                          • 4129
                          #252
                          yes you re right but these 2 kg of the crank can be shaved off the flywheel also + less piston weight compared to the stock or diesel ones.
                          Go Holset or Go RS4
                          • lind4hl
                            • Jul 2008
                            • 2465
                            Jamo, an engine with longer rods wont allow as much rev as an engine with less stroke
                            look at an F1 engine or something, huge bore and small stroke.
                              Reread my post, i'm not talking about making revs i'm talking about power made high up in the revs
                              Strokers can be revved to stock redline no problem.
                              • prosty
                                • Jun 2005
                                • 1114
                                Use NOS for your current setup, problem solved
                                2004 9-5 aero
                                2009 Subaru Legacy Diesel
                                1994 Toyota Supra Eurospec 6-spd LHD
                                3-4 Audis in parts
