450hp "(NOT)enough power" project
  • aronmatic2
    replied
    no post long time ago.
    i had 3 days for work on my car.
    it needs the wireing for standalone ecu and the exhaust system.
    i have one more week for finish the engine bay and the suspension,brakes and the rest.
    maybe in end of september.
  • aronmatic2
    replied
    the engine ready. i am waiting for couple of parts from usa and the im from polisher.
    replied
    Best get buying Avant rear benches then!
    What the seats out of or are they off the shelf Recaros?
  • aronmatic2
    replied
    Originally posted by Andy_Casey
    Nice but you'll be getting them re-covered then?
    yes. that is why i looking for quattro satin cloth
    replied
  • aronmatic2
    replied
    seats arriwed
  • EspenW
    replied
    Originally posted by aronmatic2
    i allways measuring intake temperature. geting hot on heavy traffic. the air has no time to geting hot. did you mesured how much air needs the i5 engine in one sec on 6000rpm?
    did you measured how much air changing at 90km/h under the hood? i think lot.
    i learning this, long time ago.
    The IAT's will naturally rise even more at low speeds in heavy traffic. However, the hot components will continually heat the surrounding air, and an exposed filter will suck it in. If this was not the case, you would measure ambient temp (outside temperature) at the filter surface. Temp at the surface of the filter represents the temperature of the air before the intercooler.
    http://www.kennebell.net/techinfo/ge...AirWARNING.pdf
  • aronmatic2
    replied
    Originally posted by EspenW
    I have measured 60 degs at the surface of an open (but shielded) cone filter on a day with 14degs ambient, going 50km/h+ That translates into a massive power loss.
    The turbo/manifold area of the I5 gets way hot. The designers even put heat shields on the sealed airbox..
  • EspenW
    replied
    when you going with 20km/h, the air changing much faster in the air filter area, than the engine use. if you go faster, its changing more. i measure the intake air temperature in my ecu. nothing big different, only when you stay in heavy traffic. if you stay in heavy traffic, you dont need cold air.
    here is a link
  • aronmatic2
    replied
    Originally posted by AndersS2
    Silly me, I though you'd go for the standard motronic managment
    Yes, then i understand.
    i am not smart enought for motronic.
  • AndersS2
    replied
    i dont want to make any system, only an airfilter direct on turbo.
  • urquattro-island
    replied
    really
    nice going man, looking forward to this. Ps pm...
  • aronmatic2
    replied
    Originally posted by prosty
    LOL aronmatic you're the fricken Energizer Bunny hahaha , keep it up!
    if i finish a car for myself, ready for use, the setup is working fine, its going out of my intrest. i like to do this, but i dont have realy much time.
  • prosty
    replied
  • aronmatic2
    replied
    Good idea. Superheated air from the turbo/manifold area contains more energy than cold air. Same reason why the car runs so incredibly much stronger on really hot summer days than on cold days in the fall/winter.
    (or was it the other way around )
    Originally posted by Jamo
    Nice to see your building another S2 Aron, what ecu will you be running?
    i am using allways the same ecu. our whistlerracing standalone engine management.
    here is a link
