Allmost done with the interior
I am going to have to repaint the gauge surround but looks good nevertheless. Wiring it wasn't so bad. It was the fact that I had to dremel out the back of the heater vent that was a pain in the ***.
I sourced two yellow relay junction boxes from the junkyard I forget what you blokes? whats that mean? btw call it...
One is a powerfeed now for the radio and those three gauges, and one is used as a ground. There is a jumper wire on the ground junction box to the dash frame ground points and there is a jumper wire to the other junction box used for the power sunroof, heated seats etc..I finally figured out why my interior lights don't work ( don't ask, stupid answer, this is what happens when your working on too many things at once).. But that means I can finish wiring in the aftermarket alarm, hopefully all the interior will be in by the end of the night.
JOsh
Maybe I will put some more gauges in the other vents.. Air intake temp before and after the intercooler Damn.. So tempting.
