some test were done¡¡
new ECU with the race enginee chips and the iddling problems and turning off problems has dissapeared¡¡
well, i think the engine needs a bit of fine tuning...because is a little too rich in all conditions.
just example:
iddling at 950RPM AFR is 12.85 (more or less)
full boost conditions at 2.2 bar , the richer AFR is 10.35 /5...
car stopped and 2K rpms AFR is around 12.5
i have to say that in boost conditions the engine uses Aquamist HFS3 at 25% meth and 75% water. so i will try to add more water to complete a mixture of 10% meth and 90% water...then the AFR must be more leaner because the meth makes richer the mixture if you dont have custom mapping for it. AFAIK of couse.
next step is try the car without DV...to see the behavior when shifting from 3 gear redline to 4TH... because the electronic boost dissapear (2.2bar) and it only makes mechanical boost (0.9Bar because my wastegate spring) .... and in the first moment you release the thorttle and WOT again,then 2.2Bar again¡¡
just example:
