Here we go...
I am starting with a 1995 Audi 90 Quattro 2.8L V6. I will be swapping an AAN from a 1996 UR S6. In order to do the swap i need engine mount brackets from a B3 80/90/coupe. The v6 mounts are one piece and able to be removed from the frame. the project officially started in August 2008 with the removal of the engine. Prior to that i had bought 2bennett coilovers and an A4 sport steering wheel. Nothing to crazy just getting everything ready for the swap.
Here is a list of the parts so far:
-AAN motor w/ MTM stg 1 ECU-
-80/90/coupe passenger/driver side engine mount brackets-
-2Bennett Coilovers-
-A4 Sport Steering wheel-
-H&R 21mm Rear sway bar-
-034 control arm bushings-
-034 motorsport spec motor mounts-
-034 poly rear diff mount-
-RS2 intake manifold-
-RS2 Grill-
-Audi coupe side mount radiator-
i will update the list as new parts arrive
-RS2 Grill-
