sjw185 aby to rs2
Good to see you making progress again!
Lift is looking like a great purchase! One question, do the lift pads fit straight under the car, or do you need to go onto bits of wood first?Leave a comment:
Looks nice but after my paint peeling off within a year I decided to leave them just bare metal after sandblasting. Heat makes it bubble and crack after a whileLeave a comment:
Pedal feels really solid after bleeding new fluid.Glad you got some progress made with the dual brake booster. My RS6 booster & BMC is still sitting on the shelf
Going to get it fitted over the winter as the Mrs doesn't like to drive the coupe due to the old school brake assist.
How is the pedal feel with the 27mm master cylinder?
Only had the 3b in/out the garage under vacuum once and is still on rusty disks so cant really comment on performance yet
Got rid of Procon 10 and brake bomb.
Wanted to get a power plant installed without messing about to much so painted the block and brackets and installed ABY removed from other S2.
Couldn’t use the 2 post lift to install the engine this time as car was rolling out into the back garden so borrowed a engine crane for a bottle of malt.
3b Resurrection Part 2
Andy10vs 3b is a bit of a legend, been on the forum with various Scottish members for the last ten years.
So when it came up for sale and the shell was probably going to head to the scrappers I had to buy it.
It’s good to keep it alive and hope I can get it back on the track again
Some History
Time to get the 3b indoors
One S2 pulling another
Running in new fuel lines down nearside, Filter and bracket
Removing the old servo
Comparison with vac brake booster.
Found removing dust seal from brake booster allowed you to fit using original top hat bracket.
Top hat bracket had to be put back in bulkhead first as you cant turn the fixing nuts once booster is in.
Ground down spacer so it fitted flat against the top hat
Fitted tophat in place and turned bolts so booster could fit in.
Once in I replaced dust cover/rubber boot back on the booster.
Booster installed
Had a hard time bleeding the clutch but read on the forum someone pushed fluid up from the clutch bleed nipple so tried that with the easybleed and worked a treat.
Brakes bled and pedal feeling good.Leave a comment:
Great to get the ABY running again, rebuilt engine now run in and car passed MOT a couple of weeks ago.
Just going to enjoy the car just now before the next stage.
Got a lot of tidying up to do but as long as its running that will get sorted in time
Moving faster.....
Check out this thread on lifts
I don't have the full height but doing fuel lines sitting on a office chair is awesome.
Poster I got through ebay it was originally out of a magazine as its got the marks of a folded poster.
Hope the bumper is moving faster that in was in my back garden
Thanks for the information....superb stuff!
Since buying, another S6 found it's way here along with an A2 so bumper plans
have been relegated but not forgotten! Trials and tribulations of an Audiholic.
awesome !! great job
sadly i haven't the area to put a lifter like you in my garage,Leave a comment:
Cheers Mike maybe make a meet one day
