James i just removed all the looms from my s2. Inside and engine bay. There is a huge amount of cable there, are you sure you want to recreate all that!
Which ecu are you using ? will it feed data to the dash ?
Tatech 32bit Pro
Dr Wimborne at race logic sent a cable that he says should work, if not i have full susport fitting it from them. So either way
Good luck
Ah the stock looms are a blody mess Bo its like a cancer!
I have a loom here that will do every thing and its 1000% simpler
No No No, why would you? Scared the life out of me just looking at the pic Hope you end up with what the car you want after all the hard work, much luck
