project avant 450 ish
  • keithsw0
    • May 2005
    • 571
    got aby cams and 3 inch turbo back exhaust coming
    and spraying should start in a few weeks for the shell will post some pics when i have
    • keithsw0
      • May 2005
      • 571
      head studs
      have arp head and main studs on way
      and some scat rods
      so now can start buliding engine which is going to be done by pete at white cottage
      the shell is going to the sprayers in the next few weeks and having the arches done
      will post some pics as soon as i can
      • keithsw0
        • May 2005
        • 571
        few more bits
        hi quick update few new bits
        heavy duty n75 thanks s2 bo
        recaro pole postion seats x2
        front grill
        new set of badges
        hi output coils
        fiber glass bonnet
        and plasma and carbon clocks
        will be going up to sprayers in a few weeks and get some pics up
        • keithsw0
          • May 2005
          • 571
          turbo
          been emailing 034 and have decided to go for the precsion 5557 turbo spools up quiker than 3071 and put out more power
          can any one tell me how much 340lb ft is in nm thanks
          • Bram
            • Aug 2006
            • 2582
            460 Nm
              Originally posted by Bram
              460nm is not more torque than a 3071 AFAIK
              You want good torque not out and not just out big bhp power for the car to feel quick.
              I've seen stock K24 turbos get 300 or more lb/ft
              • keithsw0
                • May 2005
                • 571
                they said a 3071 will make 310 lb ft and the 5557 will make 340 lb ft they said all tried and tested
                  Thats on the sh*te 034 chipset, ask Jade about them
                  Looks at Ross's project 400, or Brams / a80avant project with the 3071
                  Or read the write up of the Newsh Coupe on the 3071 once mapped
                  • keithsw0
                    • May 2005
                    • 571
                    nice one wont listen to that then it will make more then thanks
                      Ross's 3071
                      A80avant 3071
                      • A80Avant
                        • 10873
                        • Country: Greece
                        #71
                        and im not really a tuner!
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #72
                          i have a friend here "Manuel Garrido" forum member who had very recently 305cv and 460nm with a S2 3B all original except a full 70mm super sprint exhaust sistem with a MTM software 1´5bar , 250kpa map sensor and RS2 IC...and nothing more...¡¡
                          i think that his results were awesome for a "original" 3B... of course with 3B airbox too¡¡
                          i will upload his dyno results
                          • GazzaG60
                            • 4133
                            the precision will outdo a 3071.
                            depending on ther spec of the precision. going for vband and bb will lake it a winner. as a STOCK item not a lot to choose.
                            id expect its america so we are talking wheel not bhp.
                            torque is not the be all and end all. id expect more torque from my bmw 530d than my s2. its not faster though. by a long stretch.
                            i want a torque plateau not the equivelent of premature ejaculation.
                            how do you define a tuner Vas. ive seen many a worse result from "tuners" than you have there. im not a tuner but ive fixed a few "tuners" maps.
                            • A80Avant
                              • 10873
                              • Country: Greece
                              #74
                              i define him/her as a person getting payed to tune the map of an ecu.
                              i agree for the premature ejaculation. it is not a very good thing.
                                No disrespect but was in relation to the figures given by 034 and not referring to diesels.
                                The 034 quote was 340 lb/ft 460 nm torque which apparently is more than a 3071 which is not the case.
                                Whether it can or can't cant confirm never seen a plot this is going on the suppliers data.
                                The I5 power delivery is not like a diesel at all.
