My 3B to RS2 project
  • Dan
    • Jun 2008
    • 1242
    Originally posted by newsh
    This car is ridiculous now, it used to be a beast but now its a complete animal, I swear its breaking traction in 3rd.. (or I've got some bushes gone.. )
    This is what the forum does to you.
    1993 ABY Coupe | BMW R1200 GS
    A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
      I don't know if its a year in a 300 ish hp Avant but I kid you not this thing scares me
      The Wagner manifolds and IC kit has made a massive difference to the spool, it just gets up and goes now.
        Rear bumper is on and wheels changed for 17" Superleggera
        • andy10v
          • 5996
          Need picture updates, and a video :mischeif:
          Wheelsping in third sounds fun/frightening.
          Sold ABY-stock
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            #440
            Pretty lively these tuned 3B's, eh, Newsh?
            Nice choice of wheels too.
            SS
              Yeah, well lively, just been for a quick blat Will get some pics and vid when the front bumper is fitted
                sweet, looking forward to seeing it
                    New discs and pads on the front
                      Still trying the stop the water getting in, I've raised the windows a couple of mm both sides.
                      While I had the door cards off I've fitted some completely pointless but lovely carbon trim thats been sitting in the garage for a few months
                      I've had a reply from Sebastian Funk at Audi tradition about the rubber door trims 56 quid for the 3. Will order tomorrow, still need the missing one..
                      I've now got a couple of second hand 3B oil coolers and pipes, hoping to make up a decent set out of them, swapping back from ABYtype cooler.
                      Also bought an exhaust system so my low milage 034 full turbo back 3" coupe system will be up for sale soon!
                      If I've finally sorted the water ingress (not holding my breath on this one ) then I'll put the carpet back in with the new sound deadening.
                      Opening rear windows still to be fitted.
                      • andy10v
                        • 5996
                        What exhaust have you got? Why are you ditching the 034?
                        Good luck with the water, I am still carpetless, sponge in permanent residence.
                        Sold ABY-stock
                        • AndyP
                          • 6049
                          I wouldn't risk a 2nd hand oil cooler when a new one is only £45.
                            The 034 is a bit loud for me so I've bought a 3" custom one with a much bigger back box which should be quieter.
                            I'm hopeful on the window adjustment, I've done most of the other things, sunroof, holes in the scuttle, bonnet pull cable etc.
                            I agree, I changed my 3B cooler to an ABY one afew years back but its now damaged and with the 3B cooler cores being so cheap I wanted to collect a set of 3B pipes and the adapter plates and bolts a fit a new core. I lost my original one a while back..
                              The girls seem to be getting on ok, no fights yet..
                                Well, after the N75 Saga I looked at all the 3B oil cooler bits I got from Jonnybravo and avants2turbo and managed to make up a set with what looks like an almost new core decent brackets and good pipes. Pulled the temporary green bumper off and fitted the cooler, on with the repainted indigo non washer bumper, looking good Swapped the headlight bulbs for Philips Vision + and fixed the loose reflector in the LH one which had come disconnected from the adjuster motor.
                                Took it for a blast
                                Jobs still to do.
                                Opening rear windows.
                                Cut sound deadening and refit carpet ...if water leaks are fixed...
                                get passenger seat fitted to subframe, only has driver's at the mo.
                                Got to change the Rad which has peeling fins, have a decent one waiting and also have the full Samco water kit to go on but that will wait for another day.
