UrS4 2.2T Avant project
  • quattro-nick
    replied
    Originally posted by Thuppu
    Did buy a 600x300x76mm IC today that I modded a bit. It's the pre-intercooler.
    looking nice thomas
  • Majorcina
    replied
    Damn thats big 😃
    Poslato sa G7-L01 uz pomoć Tapatoka
  • quattrostyle
    replied
    That's some cooling surface!
  • Thuppu
    replied
  • Thuppu
    replied
    Got a package from Sweden.
    Got the M112 mounts done today. Need only to paint them. The belt isn't going stright to the crank pulley, there will be a tensioner and a pulley that keeps the free belt short enough to eliminate belt slack... i hope. The tensioner is some Fiat model and the rib pulley is from Mercedes, ordered them from Spareto, INA brand.
  • Yuri
    replied
    Good job
  • Dima ABY
    replied
    Nice!!!!!!
  • Thuppu
    replied
    Slow progress, but at least I got the exhaust manifold welded up.
  • Majorcina
    replied
    Sent me the details via inbox please. Thank you
  • Yuri
    replied
    Originally posted by Majorcina
    What you did with your old IM? The one you build?
    Marko if you looking IM made by Thomas, I have it . I can sale it to you.
  • Thuppu
    replied
    It's sold long time ago.
  • Majorcina
    replied
  • Thuppu
    replied
    Propably not the final position for it. Just need to test fit everything so there is enough space for SC and IM plumbing before starting to make any brackets. SC intake pipe will be 4" as well as the turbo air intake. All other pipings will be 3". Also the SC belt route will be fun to figure out... may need some extra pulleys, at least a tensioner.
    This may be more how the layout will be... maybe.
  • Majorcina
    replied
    Nice position for the supercharger 😃
  • Thuppu
    replied
    700x300x100mm IC. Not much bigger will go in UrS without heavy modifications. Needed to cut the radiator fittings, and of course the radiator itself will go to the rear.
    The stroker block is at the machine shop. Finally decided to go forward with it. They will bore it to 82mm, machine the water outlet in the rear and block off the rear oil return. Decided to go with 0.11mm(0.0043") piston to wall clearance as the pistons are 2618 alloy.
    When making the new exhaust manifold, needed to emulate the tall block so everything will fit without issues.
