Audi 80 2.8-Q to 1.9TDI-Q
  • mario2005
    • Dec 2010
    • 56
    • Country: Latvia
    Originally posted by Zoig
    It's easyer if you give the gearbox code or at least tell the engine of the A4.
    Engine code is AFN
    • Zoig
      • Sep 2008
      • 555
      Originally posted by mario2005
      Engine code is AFN
      AFN = 1.9TDi 81kW
      Gearbox code DGW, type 01A. Final drive 35:9 = 3.889.
      1. Gear = 3,500
      2. Gear = 1.944
      3. Gear = 1.226
      4. Gear = 0.838
      5. Gear = 0.659
      65mph is at 2241rpm when using 225/45 R17 tyres.
      Should be perfect
      • mario2005
        • Dec 2010
        • 56
        • Country: Latvia
        AFN = 1.9TDi 81kW
        1. Gear = 3,500
        2. Gear = 1.944
        3. Gear = 1.226
        4. Gear = 0.838
        5. Gear = 0.659
        Should be perfect
        And whats abaut fiting to engine ??And shud i get rear diff to from the same car ??
        • ralleyquattro
          • Oct 2007
          • 536
          • Home: Poland Current: Canada
          Looking forward to this project!
          Later on this summer I plan on istalling an I5 2.5 tdi (code 1T) into my 90 quattro V6
          www.quattro.ca
          B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
          B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
          • Zoig
            • Sep 2008
            • 555
            The gearbox should fit to the engine, AFAIK the bellhousing on the gearbox has a boltpattern for I4/I5/V6. ETKA lists the clutch diameter as 240mm for V6 and 228mm for TDI, so the clutch and flywheel from A4 should be ok.
            Rear ratio is the same for V6 and TDI: 35 : 9 = 3.889, also driveshaft flange is 100mm on both. I'm not sure about propshaft but they are both 01A gearboxes, so i'm hoping that the 80 propshaft should bolt on to A4 gearbox. I'd rather keep the 80 rear diff as it has manual diff lock in it.
            • mario2005
              • Dec 2010
              • 56
              • Country: Latvia
              #21
              Get the engine out from donor car 2h work and done nice and smooth
              Then started easy thing Wiring All out front panel heater etc
              And after some hours of its done
              In this moment looks like its will be not so hard to change original wiring from 2.8 to this one only thing whats worry me is immobilizer but we will see
              Next thing what i found out taking wires out was small issue about accelerator pedal need to use one from diesel and take all pedal housing out Because diesel have electric accelerator pedal but 2.8 manual.
              Every second i spend on the car i understand more and more that idea to buy whole car was the best because so many bits and pieces are not the same.
              Next on the plan is
              1)
              Sort out engine mounts original 2.8 no good original 1.9 nearly impossible to take off
              2)Gearbox
              3)taking apart 2.8
              If somebody have some advice or think i am doing something wrong
              • mario2005
                • Dec 2010
                • 56
                • Country: Latvia
                #22
                Get the gearbox yesterday
                But like usual nothing is perfect
                I get it defected with middle differential problem but its ok because i have my original petrol gearbox i was thinking just to swap them etc
                But when i opened i i found out bad surprise
                Can somebody help me with advice how to get that bearing off the shaft and where to get new one ????
                And second thing can somebody tell me whats missing in this picture ??
                How many number 1 rings need to be inside ??
                And whats the number 2 in picture ??
                • Mark.se
                  • Feb 2007
                  • 131
                  • Home: England Current: Sweden
                  #23
                  Hi,
                  Not sure if this is any use to you, I *should* have a spare 5 speed gearbox from a 80q 2.6 V6.
                  Pretty certain we met at Eric's (Warrington, on the same road quite near to you) when you and 'Spions' looked at the parts from the green S6 I'm breaking, I remember then you mentioned about the TDi conversion you were working on.
                  I'm back at Eric's from Tuesday onwards for about a week.
                  2007 A4 2.0TS quattro (220)
                  1995 AAN powered 80 quattro (MTM Stage 2, MTM hybrid turbo, MTM ecu, Forge DV, 034 Highoutput Coil Pack Conversion, Wagner Tuning EM, 3" turbo back SS exhaust system, race cat + other bits and pieces)
                  • mario2005
                    • Dec 2010
                    • 56
                    • Country: Latvia
                    #24
                    Yes that's me
                    I have the same gearbox left from mine 2.8 quattro just in this moment i am looking for the best way to save both of them
                    But i will definitely com to see how is yours building
                    Still looking for part number or ideas abut bearing
                    • vag_nutter
                      • Sep 2009
                      • 164
                      • Country: New Zealand
                      #25
                      Hows this going? Have been thinking about doing the same with my 2.6 avant quattro
                      • Mark.se
                        • Feb 2007
                        • 131
                        #26
                        Like wise, how's it going? Cheers for popping along to Eric's for a chat when I was over.
                        Got the 80q back home now, had a few teething problems, as good as sorted now
                        • mario2005
                          • Dec 2010
                          • 56
                          • Country: Latvia
                          #27
                          Its gojng slow now MOT first and then will begin will keap updated
                          • simon20vq
                            • Dec 2010
                            • 1379
                            Looking forward to seeing this as tempted to convert my 90 to TDI. Take lot's of pic's
