Originally posted by cowboy
View Post
audi 80 2door sedan VR632T engine + 0B4 gearbox from Poland ;)
Sold ABY-stock
Is the bell housing the same as other Audi boxes allowing it to be bolted to 5 cylinder engines?
If it will hold the power the best thing about it are the positions of the driveshaft flanges. You could move the engine back a long way and drop it a bit and still maintain good shaft angles.
Originally posted by andy10v View PostIs that not similiar to the skyline one, but taking it off the torsen rather that a transfer box and keeping it all in the gearbox? I guess Audi could extend that forward shaft even more and get the front diff under/alongside the engine?Go Holset or Go RS4
Originally posted by G60Rallye View PostIs the bell housing the same as other Audi boxes allowing it to be bolted to 5 cylinder engines?
I use the strongest clutch from 3.0 TDI (2x228mm clutch - I think 700 NM from 2000 rpm will be no problem) which is mounted on 10 bolts to crankshaft !
new gearboxes 0Bx series are in A4 B8 and A5 / S5... with 2.0 TDI, 2,7 TDI, 3.0 TDI and 1.8 TFSI, 2.0 TFSI , 3.0 TFSI and 3.2 VR6 FSI, 4.2 V8 FSI engines
this engines were in A4 / S4 B7 and other cars... I do not think so that they changed so much
0B4 bell housing looks like 01A or 01E but is different..
Originally posted by G60Rallye View PostIf it will hold the power the best thing about it are the positions of the driveshaft flanges. You could move the engine back a long way and drop it a bit and still maintain good shaft angles.
blue line shows end of I5 2.2T engine
red line shows end of VR6 engine with 0B4
on pics is VR6 with 01A - gearbox 3cm moved back from standard position
it is about 20cm better - 15 cm gives me gearbox
2.2T block has 51cm, VR6 has 43cm + 3 cm adapter = 46, so 51-46 = another 5 cm
VR6 + 0B4 - only 50 cm from center of driveshaft flange to end of engine
final drive ratio 084 is 3,89 (35/9) - i have bought diff from B4 coupe with 2.8 V6 AAH engine - differential bolt on to B3 subframe and has 35/9 ratio
B4 coupe CAU rear diff
polycarbonate side window with 2x3 inches NACA ducts
final position of engine
soon more pics
725x480x40mm radiator from audi A8 4.2 V8 + 2x14 inches pusch vent.
intake manifold
custom instruments
engine finally installed
tilton pedalbox
Good work mate, will be good to get my car and your car together when they are both finished
