audi 80 2door sedan VR632T engine + 0B4 gearbox from Poland ;)
  • cowboy
    • Mar 2011
    • 42
    • Country: Poland
    hello everybody !
    I started build this car 2 years ago, but idea & plan was in my head over 3 years ago..
    I have looked for 2door sedan quattro for almost 6 months..
    I decided use VR6 engine, like 034 motorsport in A4 B5 but connect with the best manual gearbox from VAG - 0B4 (audi S5 4.2 V8)...
    it is probably world's first audi quattro with VR6 R32 turbo engine longitudinal and new 0B4 gearbox
    link to polish forum:
    Short description:
    Audi 80 B2 2-door sedan quattro 1985 (only 400 car was made ever as 2door sedan quattro)
    ENGINE:
    3.2 VR6 24V aka R32 stock n/a 240 hp
    turbocharger: GT35/40 hybrid replica twinscroll, 1.06 AR
    wastegate TIAL 44mm V clamp
    injectors 850cc siemens
    2x bosch 044
    big fmic
    standalone megasquirt
    oil pan - touareq 3.2 V6 (VR6)
    custom adapter plate to 0B4 gearbox series
    custom intake manifold
    GEARBOX
    0B4 - torsen 40/60 from audi S5 V8 4.2
    clutch: dual disc from A5 3.0 TDI
    torsen from audi V8 in rear differential
    hub conversion to 5x112
    suspension coilover H&R / Bilstein B8
    full roll cage - IRECO Motorsport
    custom camber /caster plates
    steering rack S4 C4
    electro-hydraulic steering pump
    BRAKES
    front: 345/32 disc, big brembo 6 piston (touareg)
    rear: 330/22 disc, brembo 4 piston (touareg)
    floor mount tilton pedal, new series
    BODY KIT:
    replica B2 from Audi Museum Mobile (Bergmeister / Novak) - made by SCHMIDT GFK
    sport quattro hood replica - AP Motorsport
    WHEELS:
    Compomotive MO 7,5Jx17 - looks like A1 wheels
    adapters 5x112 to 5x114,3 - 50mm thickness
    tyres 225/45/17
    INTERIOR:
    DEFI link meter system Boost, RPM, oil pressure, link display for temperatures oil and water, EGT
    NRG quick release
    MIRCO S3 seats
    I am going to finish project in this year...
    my goal is more than 400 HP and less than 1200 kg, i hope this car will be competetive to evo and sti on track
    few pictures:
    my inspiration, audi 80 from museum mobile in Ingolstadt
    steering gear from RS2 - 2,5 rev from left to right
    turbocharger:
    wastegate
    body kit from http://schmidt-gfk.de/
    sportquattro hood replica - by AP Motorsport
    coilovers H&R bilstein B8 monotube
    rollcage IRECO MOTORSPORT
    first fitting:
    to be continued
    I hope it is interesting project....
    https://www.facebook.com/audiB2quattro
  • cowboy
    • Mar 2011
    • 42
    • Country: Poland
    wheels
    BBS RC326 from audi A4/A6 7,5Jx17
    Compomotive MO1776 7,5Jx17
    differents
    BBS 39,5cm
    compomotive 41cm
    brakes
    R32 + 0B4
    dual disc clutch
    custom caster/camber plates
    hydraulic hand brake
    NACA ducts
    talbot mirrors
    • cowboy
      • Mar 2011
      • 42
      • Country: Poland
      custom instruments project
      theory about gearbox
      clutch
      • lightman
        • Oct 2007
        • 1
        • Country: Poland
        Great project and good luck cowboy
        • Tonks4x4
          • Nov 2005
          • 3062
          Good luck with the project, I also have a 2 Door sedan quattro, I also liked the car in Ingolstadt museum...
          However I am going for the 4.2 V8 FSI RS4 engine....
          Audi Nut!!!
          • robo
            • Aug 2004
            • 2086
            • Home: Poland Current: England
            Hi Bry, this is the guy I posted the link for your gt bits.
            sigpic_________
            Rob
            • cowboy
              • Mar 2011
              • 42
              • Country: Poland
              Tonks4x4 i found your project here couple weeks ago and now decided show mine
              i thought about V8 before but finally i've chosen VR6 because i want to do something new we have few B2 quattro with V8 engine in Poland...
              • terrybullwon
                • Mar 2006
                • 8782
                Nice!
                Good cage and where did the compomotives come from?
                Chef
                • cowboy
                  • Mar 2011
                  • 42
                  • Country: Poland
                  Originally posted by terrybullwon
                  Nice!
                  cage is from IRECO motorsport
                  more details
                  wheels i won on ebay in UK - it was occasion, so decided change to 5x114,3 to japanese standard because I need 40mm adapters... earlier i changed from 4x108 to 5x112 (I have mcpherson and all suspension from B3 90 7A)
                  wheels looks like speedline from A1
                  • andy10v
                    • 5996
                    Cool project.
                    The location of the output shafts on that gearbox is awesome, should be able to get the engine in the right place.
                    Is the firewall going to be modded?
                    Sold ABY-stock
                    • cowboy
                      • Mar 2011
                      • 42
                      • Country: Poland
                      Originally posted by andy10v
                      Cool project.
                      Yes, firewall is cut off right now, and engine went about 5cm back
                      the firewall will be moved 15 cm back, must be place for pipes from water pump to radiator installed in trunk
                      driver seat is moved back about 20 cm - back of seat almost touch the main cross of the cage
                      soon will be update with pics final position of engine
                      • G60Rallye
                        • Dec 2006
                        • 1321
                        The gearbox is very interesting. Do you have any more information on it?
                        • quattro84
                          • Mar 2006
                          • 947
                          I know that they were planning someting similar for the A4 platform some time ago. Let's hope it can withstand the abuse.
                          In Dutch though:
                          Awesome project by the way, i like a blown VR6
                          • vcosmin
                            • Apr 2008
                            • 644
                            • Country: Romania
                            What gear ratioa has gearbox, does have any upgrades for bigger torque cars?
                            Sent from my GT-I9000 using Tapatalk
                            • cowboy
                              • Mar 2011
                              • 42
                              • Country: Poland
                              this gearbox does not need any upgrades - i think up to 1000 NM
                              gear ratos and speed for different rpm - 215/45/17 wheels
