Morning, time flies here. I now attached images instead of hosting on my own site, hope the images are now better visible.
anyways, quite a large update. RS2 was torn apart again, this time we (and I must say, we, because my son is involved now and teaching him RS2 knowledge and skills) tackled a full gearbox, engine and turbo rebuild. This car had a hard life, in all honesty. It has been thrashed when it got stolen many years ago, and the gearbox was in very bad condition. I never bothered to fix it because of the SQ project. So now I did. I had to replace numerous gears because of broken teeth. So I replaced all inner gears from a donor gearbox and refreshed the synchros with the newer carbon ones. As all the seals etc got replaced.
The engine we upgraded with JE pistons and a set of stronger rods. The head was in very bad condition, so major work was done to it to restore it. Welded again around the spark plugs , new seats, valves etc etc. Cams and crack were damaged and needed to be professionally fixed by adding metal with electrolysis and then grinding them to oem spec size again.
Made some heat shields again, this time on the English wheel and thought my son to start shaping some metal the old skool way.
Tackeld rust gremlins in the engine bay and had it sprayed again so all rust is gone now.
Upgraded the oil cooler with an ally one.
Now it's running again, but still not great, so I need to figure out why. anyway, so far the update
So that demystified the issue, at least to me, for now....
