Started on some maintenance last week to get it out of winter storage soon Cant wait!
V6quattro +600Whp Avant project
thanks!
On my last trip in October last year I noticed the car was running a bit lean on full power so I inspected the fuel system today. Opened the main fuel filter and all looked good. I also pulled the pre filter from the fuel tank and that was very dirty cleaned it so it should be better now! E85 is some nasty stuff1360kg/600Whp Avant 0-200km/h 9sec
Do you have some stock fuel hoses or fuel lines still in use? My theory about the black sooth with e85 is that it dissolves rubber surface and dirt from the orginal/old fuel hoses/lines, and it get in the filter and also end up on the injector tips. I got that black sooth on my injector tips soon after I started to use e85, but then never again after cleanup. Also some black dirt in the filters.
Originally posted by Thuppu View PostDo you have some stock fuel hoses or fuel lines still in use? My theory about the black sooth with e85 is that it dissolves rubber surface and dirt from the orginal/old fuel hoses/lines, and it get in the filter and also end up on the injector tips. I got that black sooth on my injector tips soon after I started to use e85, but then never again after cleanup. Also some black dirt in the filters.
Nope running all Teflon lines and aluminum fuel-cell not a original part left in the fuel system. Installed all this 4000km ago and now is the first time i cleaned the filters.
Still have some black stuff at my injectors and on the intakevalves way less than before but still there. Really don't know why
I now have filed the system with patrol to clean the intake valves. I will run one tank and see if they are cleaner.1360kg/600Whp Avant 0-200km/h 9sec
Originally posted by s2dk View PostIs your head Stock ? No porting or anything other than valve job?
Is teflon better than normal fuel Lines and kobber pipings?1360kg/600Whp Avant 0-200km/h 9sec
