UrS6 Saloon restoration
i have the same frontbrake behind 18" avus
but not a better picture at the moment
I was about to say 19" nooooooo!! I roll on standard Avus, but... They look great in the picture!Leave a comment:
almost done...
News news news...
Have done my suspension struts at the front and also my adapters for the brakes have been done, (Everything is loctited after the photo shoot) also a big thanks to Thuppu for adapter models and brake hose brackets !
Found some suitable cable connectors for the pad warning cables
brakes are bleeded, coolant is bleeded and Everything seems tight. Just a Wheel alignment, exhaust install and a AC-bleed and I'm back on the road. Have to buy bigger spacers to fit my Wheels, anyone that know what kind of ET you need for a normal stance with this calipers? my set of BBS Lemans has ET35 but with shallow spokes they touch the calipers without 15mm+ spacers
Did make a copy of the Thuppu Cayenne brake adapter and have it done in aluminum in cad, going to try em out to see If I can use them. Then maybe other people are interested. They are for the HP2 struts by the way.
I have also sorted the missing parts to the front suspension
Had to buy em from the stealer, but got it from Germany trough Heiko @ au-tel.de so I was only half the price
He was nice to send me a pen
Have probably bought stuff trough him for like 1k£
Any who, things are looking brighter and I can see the light. Although I just bought a house so I hope I can sort out the car before the move in August... but things need to be done there as well
Thanks Thuppu, yeah something came out of them, a friend is going to CAD read them and hopefully i can make more... They are not quite The same as yours... Only one hole is in The same place if I remember...
Yeah The cold intake is quite nice, The bigger turbo in stock place interfear with The stock inlet so had to make this variant
gonna fix The last bits under The car then The struts will hopefully get installed soon, have some grinding to do on The valve cover and then The smurfblue cover is gone...
Nice that you got something out of the adapters. Also nice air intake mod.
Old crap is out and new compressor installed:
Also installed my K27/26 Hoffer turbo that I bought from a member, a Swedish member, he just bought it from another s2member with shot seals and did a make up with some cleaning and stated it was like new, flushed the exhaust with almost a liter of oil in seconds... needed to ship it to total restoration and now it´s working hopefully
last moron isn't born yet...
needed to make a adapter/shim from an old oil pipe
rear brake as stated before is assembled:
And also my Apikol motor mount is in Place
That looks good, I like watching pics of nice clean/new car parts being installed
Got some garagedays and have some few updates:
The rear is now complete even with rear brakes Thuppu style and the brackets for my Cayenne caliper is done, a big thanks to Thuppu for providing his version of the brackets that I remodled for fitting with HP2 struts, couldnt use exactly the same boltpattern and needed to make some own bolts to my struts to fit. Black coated everything with a electric zink method.
Have also made a new Cold airintake thue to bigger turbo and the oem inlet was in the way of that, the oil cooler was in desperat need of a ultrasonic bath as it was pilled up with gravel and such
Also bought a new compressor dead cheap for 265£ here in Sweden
Maybe I can install my front struts this weekend and start bleeding the brakes.
Have also installed the new apikol motor bushing and have istalled the propshaft and Everything around that. Exhaust is still on the floor but will toss that up in the next couple of weeks.Leave a comment:
