Did the valve stem seals in situ yesterday. Made a tool to compress the springs and used my leak down tester to pressurise the cylinder to 50 psi which held the valves fine.
I hope this solves my issue of smoke on over run but not sure after reading JP's reply. Only a road test will confirm.
Just out of interest have these been swapped now and did it sort the issue?
What colour is smoke?
Reason being valve stem oil seals only serve one purpose and that is to prevent oil seeping down the stems when the car is parked up so it doesn't smoke on start up. There is lots of cars out there that don't even have them.
Smoke on overun is normally worn guides or valve stems. It can also be rings or turbo seals. If it does it at idle then it indicates crankcase pressure pointing towards blocked vacuum system and again rings and turbo seals. If colour is blue its oil that has burned in combustion cycle which is rings. If the smoke is grey its post combustion cycle pointing to guides or turbo seals.
I'm really glad you said this as I had an argument on here some time ago
with someone saying oil smoke is always blue, I insisted it wasn't and it can
be grey/ white.
I know from experience that when you loose the head off an exhaust valve and it puts a hole through the piston that the smoke is grey/white not blue, across all three lanes of the motorway in my case like a James bond style smoke screen .
it has been done on my current set up, not the new engine on this thread...and yep, it sorted it out and its clear now....it was the odd waft of blue smoke when I was crawling through traffic and when, for example, I was slowing to a junction and then almost coming to a stop it would pop out some smoke...but this got gradually worse
the seals were in a real mess when I took them out....literally where they would sit around the valves was a large build up of carbon and they had gone so soft it was un-real....to be honest the exhaust's were a lot worse than the inlets....
I hear what your saying about what casuses these things but it seems a little odd that it is ok now after changing these....
on with the build story.....
After assembling the top end, install the ARP main studs, drop the lifters into the head and then lube the cams up to give them a fighting chance...... it was then time to try and see if it turned over by hand...which it did for about 1/4 of a turn and then locked up...
something isn't right undo a few things but as the head was torque'd down, I didn't want to undo the studs and sacrifice a perfectly good head gasket...
we then tried it again.....and still the same result...during the next few times a light pinging was heard.....WTF is that.....
Have you used arp head studs and adjustable cams wheels? did you check the clearance on the back of the cams to the arp spacer? as you have to grind the arp spacer if there is no clearance
Double check the cam caps are the right way round especially 6 and 9!
Also the skinny front one. All the recesses should point towards the inlet side of the head when fitted.
yep, found out the hard way with a little bit of "crunching" eminating from the pulley last week.... sorted now....
yep, did that too.....
not so much the 6 & 9 as there is a dot next to one of the numbers...6 IIRC but it was the thin cap that fits over the inlet at the gear end of the cam shaft that caused the headaches.......that didn't help.... again sorted a few weeks ago.....
the problem was when the ARP's were torqued down they were pinching the lifters to such a degree it almost appeared the engine was seizing....
so hence why the valve tool came back out...I removed the lifters with great difficulty and honed out the lifter bore just enough to let the lifters sit back in head snuggly...
but some problems/damage had been found....namely the main pulley pin....
not bad for a nights work....well it should have been a nights work.....
it seems everything that happens to this engine, it seems destined to be removed and re-done again for some reason or another....at least its starting to take shape...
