I dutifully delivered the car with a game plan unfortunately things transpired against me once again. After numerous test runs and 2 bar holding no bother, the car was tucked up over the weekend and checked again the following week. Low and behold no boost, nothing....I gets the phone call "Mike, its your turbo"...ah nuts I thought (well censorship stops me from putting what I really thought!
bloody cars)...luckily it had only jammed the compressor and not passed through the motor. Where it came from is a mystery but to be on the safe side it was sent to TDi turbos in Poole to have a complete check over. While it was there I decided to swap the hotside as the previous one had a 6 bolt flange which is rather tedious when your trying to remove the DP and the bolt is right under the pipe...and I wanted to improve the spool up without forking out for a new turbo.
It was then returned to the Mark for the remaining work which finally came to fruition 3 weekends ago. I had been out in it late last year but once again ill health played its cards....so it was left until the coldest snap of this winter when i finally went to collect it.
I'm still getting used to it...and the fact that it stood on and off for a long time has had an effect on the suspension I feel so thats whats on the cards now so I can really enjoy the car.
One thing I'm not totally sure about the screamer pipe and as I planned to take it on the track I might not be very popular....
bloody cars)...luckily it had only jammed the compressor and not passed through the motor. Where it came from is a mystery but to be on the safe side it was sent to TDi turbos in Poole to have a complete check over. While it was there I decided to swap the hotside as the previous one had a 6 bolt flange which is rather tedious when your trying to remove the DP and the bolt is right under the pipe...and I wanted to improve the spool up without forking out for a new turbo. It was then returned to the Mark for the remaining work which finally came to fruition 3 weekends ago. I had been out in it late last year but once again ill health played its cards....so it was left until the coldest snap of this winter when i finally went to collect it.
