Got a couple of ideas now that I've had a nights sleep. Starting on it tomorrow morning. Until starting to diagnose it though everything is an assumption. But I don't think oil consumption and compression are related.
Let us know what you find once the head is off. Sounds very sad to have an engine die as is, but also just before mapping to be able to enjoy it! Hope it gets fixed soon and appropriately
Very long story, but never got around to mapping it.
Spent the whole day (from 10 am to 10 pm) sorting out boost leaks, relaying the fuel pump, swapping injector seats, making sure there are no fuel leaks from the injectors and so on.
After the car was stood in the workshop for a while, upon starting up it was running on 4 cylinders and there was no compression in cyl. 4.
Also, the oil level was at minimum, whereas when Mike set out in the morning it was OK.
Everything is connected on the car (RS4 MAF, etc) and it's on a map that'll let it drive.
JP is going to sort out the engine, and I'll map it in a couple weeks in Poole.
the whole day??....sure about that....but yeah it was a long day....
I suspect the oil level issue will be the fact that we had been turning it over to check the compression which in turn would have filled the oil galleries hence the variation on the dipstick...and no I don't mean me!!...
After spending the day in Queens Med today I have jumped on the forum to thank people for their support and will report my findings in due time....
unfortunately JP will not be "sorting" the engine due to his massive workload and if I find something a miss that will scupper the engine I'd rather have it locally so it can be fixed without cluttering Ish's place or JP's rather "stacked out" workshop in the long run...
oh sh*t Mike, I hope it's nothing serious and you get it fixed quickly for mapping down south. Good luck with the fix
to be honest after todays trip to the hospital I'm not too fussed...I will try and get down there and until Dmitri lets me know his spare dates I've no idea whats going to happen...
My guess is a tappet stuck in the head again so a valve is not closing and therefor just burning the oil away.
Am i tired or it is not tech possible:
A tapet stuch can remain only in its fully lower position(camshaft lobe bill push it down and if it is so stuck and can not be pushed camshaft/caps will break).
And if it is stuck in its lower position piston will hit the valve.
Or stuck in what way?
Hydraulic mechanism opened in full lenght and valve remains slightly opened?But oil can not get in cylinder by no means.
I have seen it for myself with an engine,
The cam lobe pushes the tappet down and opens the valve, when the cam lobe rotates, the valve spring is not quite enough to return the tappet and does not pop back up fully until the piston taps the valve.
The cause was torquing the head down with sportquattro washers. It spread the aluminium so slightly that the tappets were not 100% free.
The cure was to give the tappet bores a light hone.
However I don't think it is the issue this time round.
You have seen this in a cranking engine or in a engine on a engine stand hand cranking?
this did happen as Brian describes after torquing down with the engine on the stand, as it killed one of my cam pulley keys...it freaked us both out but hey it seemed to cure it after a light hone....
well finally managed to get the head off to reveal some unpleasant-ness in the head...
fragments of injector seat in the bores and "welded" to the valve seats, hence the no compression scenario....
oil level was normal.....
so the head is off ready for a check and a re-fettle if needed before re-building.
Unfortunately my health issues have stopped me doing anything on the car so progress will be "as and when!"....
one thing I will say to all building anything, mainly engines, please, please replace the injector seats whilst the manifold is on a bench.....access is so much better!!...and even if they haven't been in that long, change them anyway...
I've learnt a valuable lesson here, the hard way!.....
