My avant engine saga
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #166
    Thats a shame Mike. Try and get well soon and the car will be up and running once again.
    How on earth can an injector seat fall into the engine?
    Edit: is it that as you are trying to remove it some pieces from it disintigrate and fall behind?
    • prj
      • Mar 2010
      • 6308
      And when you do replace them please do not forget to use sealant like it is done from the factory, or they will leak!
      @Vas - yes, basically it was a choice - either send Mike home or try to remove the injector seats... It had huge leaks from most of them.
      Should have had the manifold removed, oh well hindsight is a beautiful thing.
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #168
        I see. I have to look into mine at some point. I dont remember what we have done after the inlet was changed to thw wagner one.
        • europeanme
          • Oct 2005
          • 3817
          only managed a few updates....and even less pictures....
          more to come.....
            • 12431
            Thats about as tight as you can get with that caliper. What size discs have you got in there?
            • europeanme
              • Oct 2005
              • 3817
              yeah not much room there....but clearance is clearance...
              The discs started out at 365mm but I had them machined down to 360mm to clear inside the caliper body....
              once I get the camera I'll get some more pics of the new engine bay set up
              • europeanme
                • Oct 2005
                • 3817
                a few additions....
                can anyone spot them...
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  #173
                  Oil cooler and catch tank?
                  Does it also play a role when the oil cooler is situated at the same level or lower than the oil pump?
                  • europeanme
                    • Oct 2005
                    • 3817
                    oil cooler = correct
                    catch tank = sorry chap that was on the car before....
                    try again....
                    as for the oil cooler, I'm not sure but under 5 bar of pressure it shouldn't be a problem, should it....
                    • JP
                      • 1858
                      Turbo blanket
                      UrS6 Stroker + HTA3586 =
                      • europeanme
                        • Oct 2005
                        • 3817
                        Originally posted by JP
                        Turbo blanket
                        the boy wins a prize!.... well spotted...
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          #177
                          So you have a new coolant warmer ready for the winter then Mike. It's mounted upside down though.
                          SS
                          • europeanme
                            • Oct 2005
                            • 3817
                            I know its been a very long time but luckily I've come out the other side with a working S2....still getting to grips with it and as the heater matrix has needed doing since god was a lad it doesn't get much use in the current climate...
                            more to follow
                            • europeanme
                              • Oct 2005
                              • 3817
                              something lurking in the spare wheel well...
                              Due to timing and distance I had my car remapped up at Automark's place in Stokesley.
                              I have to say if I had my time again I'd have got a game plan and worked with people instead of going off and "doing my own thing"!...
                              I have learnt a lot by my experience with this project.
                              Anywho the next part to the "saga" - which will know be known as an epic!!!...
                              After the turmoil of the previous year and a bit of ill health I almost gave up with "Skip" but after a good chat with various members on here and being able to have a blast with a couple of "stu's" I was keen to get on and fix the various issues that found their way to the surface. It appears some works that I'd been reliably informed had been done, hadn't....so a big shout goes to JP for sorting this out as does a shout to Ish at QC...
                              The engine was run in again just to be on the safe side as I replaced the main shells as I wasn't happy with the way they looked....damn my day job! I finally got it run in and ready for mapping...then there was the idea of water methanol injection to keep the intake temps down during summer...."santa/the wife!" got me the aquamist kit for crimbo so the dilemma of where to install it began. It was decided where to locate the pump and tank was easy but the injector itself was left to Mark and I think its an awesome position he has chosen.
                              • Thuppu
                                • 4115
                                Nice Mike! Any details about the remap result?
