And when you do replace them please do not forget to use sealant like it is done from the factory, or they will leak!
@Vas - yes, basically it was a choice - either send Mike home or try to remove the injector seats... It had huge leaks from most of them.
Should have had the manifold removed, oh well hindsight is a beautiful thing.
I know its been a very long time but luckily I've come out the other side with a working S2....still getting to grips with it and as the heater matrix has needed doing since god was a lad it doesn't get much use in the current climate...
Due to timing and distance I had my car remapped up at Automark's place in Stokesley.
I have to say if I had my time again I'd have got a game plan and worked with people instead of going off and "doing my own thing"!...
I have learnt a lot by my experience with this project.
Anywho the next part to the "saga" - which will know be known as an epic!!!...
After the turmoil of the previous year and a bit of ill health I almost gave up with "Skip" but after a good chat with various members on here and being able to have a blast with a couple of "stu's" I was keen to get on and fix the various issues that found their way to the surface. It appears some works that I'd been reliably informed had been done, hadn't....so a big shout goes to JP for sorting this out as does a shout to Ish at QC...
The engine was run in again just to be on the safe side as I replaced the main shells as I wasn't happy with the way they looked....damn my day job! I finally got it run in and ready for mapping...then there was the idea of water methanol injection to keep the intake temps down during summer...."santa/the wife!" got me the aquamist kit for crimbo so the dilemma of where to install it began. It was decided where to locate the pump and tank was easy but the injector itself was left to Mark and I think its an awesome position he has chosen.
