My avant engine saga
  • europeanme
    • Oct 2005
    • 3817
    Originally posted by A80Avant
    Yes but the original box is well insulated and the mushroom isn't. See what I had to do in mine?
    I do but as mine is at the same level as the bottom of the bumper right in the corner, I was hoping the airflow would reduce the heat soak....
    I thought yours needed the heat panel as the intake of the turbo/mushroom is so close to the engine....
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      #137
      Oh so you are putting it at the bottom of that area, I suppose close or above the oil cooler?
      • europeanme
        • Oct 2005
        • 3817
        yeah thats the place....and the oil cooler will be in front of the rad which frees up some more room........
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          #139
          I had that oil cooler like that before. Wasn't very nice.
          As for the mushroom it will in danger of putholes.
          • europeanme
            • Oct 2005
            • 3817
            really?...why was that??....
            "putholes" or puddles.....what danger??
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #141
              Yes meant puddles filled with muddy water in this country. It can get awfully wet so ideally you want it facing upwards to some extent or make a shield for it.
              On the rs2 bumper there was little space to fit the large oil cooler I had, 18row at the time so I had it fitted in front of the intercooler. Besides the fact it looked ugly as hell, it was stretching the metal mesh of the bumper as well as creating a small dent on the intercooler.
              Eventually we fitted the 11row one on the original position sacrificing the front tow in the process but it looks and acts brilliantly.
              • Thuppu
                • 4115
                Yes meant puddles filled with muddy water in this country. It can get awfully wet...
                Budget water injection.
                Well, I don't think that's gona be a problem. You have the inner fender protecting from direct water splatter.
                • europeanme
                  • Oct 2005
                  • 3817
                  I hope the undertray part of the bumper will deflect most of the water if not all and I will always avoid water in the road coz I'm too lazy to keep cleaning the car!!...
                  • djh
                    • Jun 2011
                    • 1622
                    #144
                    Just put it inside the drivers wing and be done with it
                    • Tonks4x4
                      • Nov 2005
                      • 3062
                      Well, it's about time we had an update Mike!!!!
                      And your phone has been off all afternoon!!! 😔
                      Audi Nut!!!
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #146
                        That's true!
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #147
                          car mapped too?
                          • robo
                            • Aug 2004
                            • 2086
                            #148
                            Originally posted by Rocco
                            car mapped too?
                            You can not wait to get yours done.
                            sigpic_________
                            Rob
                            • Rocco
                              • Aug 2007
                              • 6393
                              • Country: Spain
                              #149
                              i am crossing fingers about my clutch and transmission parts if something snappes i hope the car were almost finished
                              • prj
                                • Mar 2010
                                • 6308
                                Very long story, but never got around to mapping it.
                                Spent the whole day (from 10 am to 10 pm) sorting out boost leaks, relaying the fuel pump, swapping injector seats, making sure there are no fuel leaks from the injectors and so on.
                                After the car was stood in the workshop for a while, upon starting up it was running on 4 cylinders and there was no compression in cyl. 4.
                                Also, the oil level was at minimum, whereas when Mike set out in the morning it was OK.
                                Everything is connected on the car (RS4 MAF, etc) and it's on a map that'll let it drive.
                                JP is going to sort out the engine, and I'll map it in a couple weeks in Poole.
