shiny!!
My avant engine saga
this is how it looked by 1am on the Saturday morning...
It had gone fairly straight forward....well a bit of head scratching with the AAN clutch set up...but got sorted in the end...
There had also been a strike up of the engine without the exhaust on to see if it would work!...and it sure did...and what a noise!!...Attached FilesLast edited by europeanme; 30 July 2012, 19:53.Comment
Saturday morning came around way too quickly...and what with some abuse from another forum member
, I was on my way back up to the car ready for the day. It was downpipe time...so the day was spent offering up the DP...comparing it to the original and make the relevant alterations to fit the CT....
unfortunately my lack of "kodak moments" have come back....I didn't get a picture of the DP in all its glory...
sorry Andy...
after the fun and games of saturday and the DP/screamer pipe locating dilemma it all finally came together....
it was start up time....
with a make shift MAF set up/cold air feed the car was turned over and once we were happy the oil pressure was real, and not the wires on back to front
, it struck up... and what a noise...very nerve-wracking at first but once it settled down for a few seconds we shut the engine down.
We then preceeded to find all manner of small niggles...leaky hoses....no earth strap!!
not tight enough hoses for both water and oil...and not to mention the missing gasket on the turbo oil return line...
I was back with the engine on the Tuesday and a quick call into work, I spent most of the day running around chasing parts and getting the car ready for the road...setting the throttle potentiometer so it will at least run most of the time
After all that has gone on I am still confused as to why the idle is so erratic...fine at cold...and all over the place...and will cut out when it feels like it....has anyone else come across this after a engine swap?...Attached FilesComment
all things considered....OMG!!!...with the N75 unplugged...stock injectors....and taking it easy...it scares me now....I must do something about the slighly chavy DV sound on lift off....in my defense I might look at getting a new DV, as it is the one off my old set up....any suggestions?...
yeah it was a bit of a ****** about the hose....to be fair I was amazed at the cost of a new one and I even managed to gt some protective sleeve for it so it doesn't wear through on the chasis somewhere...
thanks for your help J....
I have some aeroquip fire jacket some where if any of the lines are close to the Manifoldall things considered....OMG!!!...with the N75 unplugged...stock injectors....and taking it easy...it scares me now....I must do something about the slighly chavy DV sound on lift off....in my defense I might look at getting a new DV, as it is the one off my old set up....any suggestions?...
ChefComment
Here is a snap shot of the downpipe for you mike...
I am?...
I didn't think I was that bad....
as for the photos, as previously mentioned I am very slack when it comes to taking photos...
Cheers Bri....I'm not sure if I've even got that one...and don't even ask about the IC pics....as you previously mentioned...I had forgotten to take any...what with trying to get it all sorted so I could get to work!...
well just done 1600 miles now and no real faults to report....the odd weaping of fluid.....idles like a bag of poop, although its better than it was.....one of the oil pressure wires came off but that didn't bother too much seen as how I put the wires on back to front anyway...
I did however have the fright of my life Wednesday evening...bear in mind that I'm still running it in on a stock MAF, injectors and map.....I've not let the engine get above 5k. I decided it was time to see what happens over that....
all of a sudden it took off like a missile....took me totally unawares....mmmmmm I didn't expect that, lets see what happens if I try it again....OMG.....one thing to point out, don't ask about the economy...those 2 short bursts of no more than a mile each...a tenner in fuel gone!...
when this gets finally mapped I am going to need some form of medication...
super UL me thinks will do just fine!...
I will try and get some more pics this weekend....
I'm thinking of nicknaming my car, Peperami...
Good going
Haven't seen this thread in over a month, didn't realise you even had the motor running. Looking forward to seeing this beast... some good rebuild projects hitting the road this year. I need to get mine running again, feeling left out from the (R)S2 fold...AUDI - saving Dad's from minivans since 1994
Keep the photos coming.
