Audi Coupe Drag/ Trackday car
  • Nik0las
    • 1345
    • Country: Bulgaria
    in order to use full potential of the turbo (i'm not even sure that you even can reach the potential with these inj.) you have to run them on 100% duty which is not save, the risk of inj. fail is to big! Specially for track/drag car constantly on full boost. My advice is that you have to consider upgrade to 630cc....
    • Rallye20vt
      • Mar 2008
      • 154
      Okay the car is chipped to about 1.5 bar.
      This will be enough with 440 cc.
      BUT when i want to upgrate to about 2 bar,
      Then i will need bigger injectors.
      Advice is 750 cc BOsch NO DEKA 630 ! HE says.
      • Rallye20vt
        • Mar 2008
        • 154
        What do i need to get the 044 bosch pomp fitted in the stock fuel tank ?
        V8 basket ??
        • Costash
          • 878
          • Home: Romania Current: United Kingdom
          895 201 779 H Basket
          895 201 531 A Strainer
          N 013 812 8 Washer (x2)
          N 011 069 1 Domed Nut
          N 903 307 01 Banjo
          • Rallye20vt
            • Mar 2008
            • 154
            N 903 307 01 Banjo
            Thanks !!!
            • Rallye20vt
              • Mar 2008
              • 154
              Today got the intake back,
              But 1 problem, im touching with the trottle the upper bolt of the steering pomp.
              How can i solve this ?
              Iff i raise the intake about 1 cm it nearly cleares, But thats no option i think.
              • quattrostyle
                • Oct 2006
                • 6229
                Lower the steering pump and use a shorter belt
                • Rallye20vt
                  • Mar 2008
                  • 154
                  Dont have a steering pump from an ABY OR 3b.
                  I have a AAN setup so far as i can see is that a fiksed setup with 3 bolts.
                  Also have a Automatic belt tensioner...
                  • Rallye20vt
                    • Mar 2008
                    • 154
                    • andy10v
                      • 5996
                      Phelonic intake manifold spacer would lift the intake manifold up and out slightly.
                      Would need to check that would be enough, and that you have space to move it up.
                      Sold ABY-stock
                      • quattrostyle
                        • Oct 2006
                        • 6229
                        Ah now I see, nice setup but a bit difficult in this case with the IM.
                        What IM is that?
                        • Rallye20vt
                          • Mar 2008
                          • 154
                          Dont know exactly has been sold as a wagner, but i dont think it is a wagner.
                          • Rallye20vt
                            • Mar 2008
                            • 154
                            How much HP And torque can my engine hold ?
                            The pistons are skimmed 1 mm off, ( not in the middle offcourse )
                            New bearings, H Beam Rods,Engine honed, New pirston rings. RS2 headgasket etc etc..
                            Im gonna drive with a holset HX35 , 3 1/2 inch downpipe, stock wastegaste etc.
                            Dont know the compression now ? I believe normal is 9.3: 1 ?
                            Originally the engine is an AAN Urs4 engine.
                            • Biturbo
                              • Aug 2011
                              • 591
                              • Home: Lithuania Current: United Kingdom
                              #29
                              Nice project .Can you make some foto of yours pistons?That you head specifics?Head is more important then bottom for more power.And that is yours holset hot site size and flange?
                              P.S now have seen yours pistons on first post
                              • Rallye20vt
                                • Mar 2008
                                • 154
                                The number in the hot size is 10
                                Dont know much about turbo sizing so placed all the photos i had
