Wanted to use some of the black one ( 5 cil 10v ) for the white one,
but as always evertyhing is different.
Will be using the body ( iff the white one gets damaged on the track or something )
and use the steering rack and maybe brake booster etc.
I now have evertything ABY , but the piece of **** intake dont fit...
I cant clear the bolt of the steering pump .
Have grinded back to get as much clearance as possible, but still not
enough.
Even iff i have a 1000 mm belt it wont clear , it sits on top of it.
Iff i only put the intake on without steering pump, it
pushes against the hood, by about 1 cm, so my first thought of
putting an intake spacer wont work, otherwise i have to lower the engine and subframe about 2 cm.. NOt good for strenght i gues ?
5 x Fuel Injector, 1700cc or 160lb High Impedance
1 x Fuel Pump, Aeromotive A1000 High Flow Pump
1 x Audi I5 20-Valve Fuel Rail
1 x Fuel Filter, Aeromotive 10 Micron
1 x AEM Analog E85 Wideband Gauge 5.7~11.9 E85 AFR
1 x JHM �SOLID� Short Throw Shifter, B3/B4 Chassis
Would the fuel pump be enough for these size injectors ?
