Audi Coupe Drag/ Trackday car
  • Biturbo
    • Aug 2011
    • 591
    • Home: Lithuania Current: United Kingdom
    #31
    Good turbo you will be close 600hp I think.You will run on petrol?
    • Rallye20vt
      • Mar 2008
      • 154
      yes 98 maybe ad some e85
      • Biturbo
        • Aug 2011
        • 591
        #33
        If you have in your country e85 and this car for race,better for you is use e85.In Uk no available e85 so I can't use this.Using shell v-power (is 99 octane) and plius methanol injection will be connected very soon.
        • Rallye20vt
          • Mar 2008
          • 154
          Any more opinions about max power and turbo ?
          • Rallye20vt
            • Mar 2008
            • 154
            Nobody ?
            Dont know how to calcuta the sizes from turbo to engine hp etc.
            • Rallye20vt
              • Mar 2008
              • 154
              Hmm today i saw a nr 12 in the exhaust housing ?
              Been trying to measure the wheels.
              Intake would be around 58 mm and exhaust about 62
              Could not measure correctly but i think its right about this size.
              • Biturbo
                • Aug 2011
                • 591
                #37
                You looking wrong.Look at your turbo hot side like in this foto
                • Rallye20vt
                  • Mar 2008
                  • 154
                  Looked at that spot but did not saw anything.
                  Ahh hell well see when its dynoed
                  • Rallye20vt
                    • Mar 2008
                    • 154
                    SOmebody who sells plug & play solution for oil catchtank ??
                    • Rallye20vt
                      • Mar 2008
                      • 154
                      Today removed the gearbox again, because it was leaking oil.
                      Gonna bring it to the repair shop , as im not very good with gearboxes
                      But my question now, i find that the springs on the pressure plate,
                      dont go as much inside as a normal pressure plate would.
                      If i bolt al 6 bolts from the pressure plate to the gearbox then there is little tension on the " Fingers".
                      As for example a VW GOlf plate you ;ll see the fingers going in quite a bit..
                      WIll place some fotos
                      • Rallye20vt
                        • Mar 2008
                        • 154
                        Its a JOE clutch with i believe 7a lightened flywheel.
                        • Rallye20vt
                          • Mar 2008
                          • 154
                          Number in the exhaust flange is 12-4 .
                          Destroyed the plug on the tailsection of the gearbox.
                          Thank god this AUdi part isnt that expensive And very easy to change.
                          Didnt see it quite well when i installed the gearbox , only saw it when the new oil came out
                          The gearbox is now in place, with no leaks at all.
                          Up to the next task.
                          Getting the intake manifold to clear the steering pump.
                          Thats gonna difficult, if i buy an intake spacer the hood doesnt close.
                          NOt a bit but about 2 cm ,s .
                          So i think im gonna rebuild the stuff to ABY specs, with other belt, dynamo, steering pump etc etc.
                          Or somebody that has an other option ?
                          • Rallye20vt
                            • Mar 2008
                            • 154
                            Somebody who has a link for wiring scheme.
                            I want to know witch wires from the engine to the fuse box etc etc.
                            • Kieron20V
                              • Mar 2008
                              • 1505
                              #44
                              Regarding the clutch, if you have a dual mass flywheel and matching clutch you will need the spacer that normally sits between the gearbox and engine as per original fitting.
                              1994 URS4 Avant RS2+
                              • Rallye20vt
                                • Mar 2008
                                • 154
                                No its a set from single mass flywheel, i also have the 5 speed gearbox so no
                                spacer between..
