Please dont shoot me !
  • R5T
    • Jul 2012
    • 250
    Thanks for the help buddy, will have a look at the rear diff mount tonight, the jolt feels like it's coming from behind, but the noise mainly seems to be coming from the box itself ? .. If the rear diff mount had let the diff sag/move, would this have an effect on anything inside the box at all ?
    Sam
    93' Audi 80 2.6 Quattro
    93' Audi Coupe 2.6E Auto
    90' Audi Coupe 2.3e 10v
    95' VW Polo 1.0 ...
    • R5T
      • Jul 2012
      • 250
      Right lads.. It's getting worse, I'm nursing it everywhere, had on the ramps to get my tracking done and exhaust welded today, I couldn't find the rear diff mount ... Got a bit confused if I'm honest. I can't see anything that would cause alarm. However, the selector arm that has the UJ on was covered in ****, and I don't know how far the grub screw on the side should be wound in ? Picture below :
      If driving in any gear, I come to a halt, dip the clutch and go to put it into first i get a metallic crunching sound and a jolt all the way through the car, however, if I then take it back out of first and do It again it's fine. It's really odd, it's as off I'm not fully depressing the clutch (which I am) .. Which would make me thing that it's on the way out, but I don't see that this would also cause the transmission jolt's ? Added to this I'm getting an intermittent "rotational" tapping from the rear end, only does is occasionally but gets quite loud.
      I'm really starting to wonder where to start ... But as it's my daily I don't want to be ripping everything apart on a Sunday afternoon !
      Any help/picture/advice/opinions etc greatly received.
      Sam
      95' VW Polo 1.0 ...
      • R5T
        • Jul 2012
        • 250
        Had another look underneathe as it's getting worse still .. I still can't find a mount that resembles the picture above, but the only mount I can find is this :
        This is the spare I had lying about, but the one on the front of the diff tunnel casing is poggered ... Got the back wheels off the floor and as soon as the find the biting point the whole diff jolts up and slaps the underside of the car, there's about 2 inches of movement. Waiting to get my tools back and I will be swapping them over to see if it makes any difference ..
        Sam
        95' VW Polo 1.0 ...
        • Kieron20V
          • Mar 2008
          • 1505
          #109
          Yeh that sounds like your culprit. Car is a b4 so the rear diff and suspension is different to all the suggestions above which are b3 cars.
          If the diff is twisting enough to hit the floor pan, the grinding is probably the driveshaft on the opposite side scraping something.
          I think I've seen a picture of one of those mounts completely cracked through so not doing anything.
          Sent from my Dyson dc09 using tapatalk.
          1994 URS4 Avant RS2+
          • R5T
            • Jul 2012
            • 250
            Ahhh right makes sense now ! Any idea where the best place would be to get a new mount ?
            95' VW Polo 1.0 ...
            • Bowie69
              • Nov 2013
              • 2675
              Oh... saw your profile pic and thought it was a B3.... sorry
              • R5T
                • Jul 2012
                • 250
                Haha no worries buddy ! .. However the crunching between 1st and second has stopped ? Not sure what's going on !! Will get that mount swapped over ASAP and see what's what !
                Sam
                95' VW Polo 1.0 ...
                • R5T
                  • Jul 2012
                  • 250
                  Just to update the thread, after a few months just commuting and no sideways action, I decided to bite the bullet, I purchased a brand new APIKOL rear diff mount which is anodised billet ally with poly bushes to suit. Here is a pic :
                  More than pleased with the build quality, and has stopped all diff movement and hast induced any vibrations !! .. Considering audi dealer wanted £146 + VAT and 034 Motorsport wanted the equivalent of £180 inc shipping from California. It was a no brainer. Better still I ordered on a Friday and it arrived Monday morning !
                  I was hoping to have pictures of my other exciting purchase .. However the company is waiting to have the item in stock
                  I've purchased a brand new set of FK high sport coilovers from FK themselves, I worked out that to achieve what I wanted in terms of ride quality/handling/lows/stiffness .. The price of the FK's was good, even better is that the FK website has a 45% sale on at the moment so I suggest some of you boys get on there !! It worked out at £360 for a set of coilovers ... Which is pretty damn good if you ask me !!
                  I also got a good deal on a set of cheapo 17" alloys as I was getting bored of mine and wanted a change :
                  Unfortunately, the new diff mount has not stopped the horrible noise, even though it's holding the diff still and solid, I'm pretty sure it's an internal diff fault.
                  There is no excessive play in the centre carrier, and nothing that looks out of the ordinary underneathe but the noise
                  Is coming from inside the diff :/
                  Hope to swap it for my spare at the weekend ! Will let you know how I get on and hope to post a complete transformation once all the bits I have in mind are done
                  Sam
                  95' VW Polo 1.0 ...
                    That grub screw on the linkage just retains it on the rod in the gearbox, it should just be nipped up tight, around 20nm if its an M8 screw.
                    The linkage is probably pretty shot anyway and new ones are not expensive, around £60 from memory - a new one will be a noticeable improvement.
                    Try bleeding the clutch hydraulics, as it sounds like the clutch is not disengaging correctly.
                    I notice you're jacking the car under the diff - bad idea. That's probably the reason yours are trashed - you've replaced one of them, what about the rest?
                    Some "slack" when coming on and off the power is pretty normal - it's the centre diff. As you are RWD you could take the centre diff out and weld it up, to get rid of the shunt.
                    HTH
                    • R5T
                      • Jul 2012
                      • 250
                      My centre diff is welded it would be RWD otherwise haha !! And the car was on axle stands in the pic, was only taking the weight of the diff to fit the new mount !
                      The thing that doesn't make sense to me is that when changing down through the box, as smooth or as harsh as you want, there is no problem whatso ever ?
                      And this is the plan, hoping to replace the other two circular mounts on the mounting plate at the rear of the diff, top the spare diff up with oil, and stick it back up and see what happens !
                      Sam
                      95' VW Polo 1.0 ...
                      • quattrostyle
                        • Oct 2006
                        • 6229
                        So you went for the FK Highsport set? Good thing about the discount. I sent FK an e-mail asking for the exact differences between the High and Konigsport sets. I'll probably go for the last one.
                        The wheels look pretty cool, like what a lot drifters use on Jap cars. Interested to see what they will look like on the Audi.
                        • R5T
                          • Jul 2012
                          • 250
                          What was the difference between the high/konig ? If you don't mind me asking ?
                          Sam
                          95' VW Polo 1.0 ...
                          • quattrostyle
                            • Oct 2006
                            • 6229
                            Well that's what I asked
                            Hopefully the Konigsport has adjustable damping, read in the past they would be Koni shocks, which would be fine for me.
                            • R5T
                              • Jul 2012
                              • 250
                              Ahh makes sense, fingers crossed they don't take too long to get here ! Hoping to post a decent review !
                              Sam
                              95' VW Polo 1.0 ...
                              • quattrostyle
                                • Oct 2006
                                • 6229
                                Sam
                                I got this reply Sam:
                                FK Coil Over Suspension Kits – SILVERLINE + HIGHSPORT
                                · Best selling coil over suspensions
                                · Both feature fixed dampening system set by FK
                                · Ideal for customers who want a set-up that has been adjusted by our Qualified Engineers
                                · Ride height and attitude can also be accuracy adjusted
                                · Share same spring and shock absorbers
                                · Come with adjustable wrenches & FK Coil Over Protection Spray
                                *** Our HIGH-SPORT range offers zinc plated steel strut housings
                                *** And SILVERLINE range offers zinc plated stainless steel strut housing. And Delivered with Stainless Steel Locking Rings
                                FK Coil Over Suspension Kits – SILVERLINE “X” + KÖNIGSPORT (KING SPORT)
                                · FK’s PREMIUM coil over kits!
                                · Each kit features unique KONI dampers produced to the exact technical specifications of FK Automotive.
                                · Ideal for customers who want both height & dampening to be separately adjustable.
                                *** The KÖNIGSPORT (KING SPORT) are available with polished zinc plated steel strut housings
                                *** And SILVERLINE “X” features zinc plated stainless steel strut housings. And Delivered with Stainless Steel Locking Rings
                                I'll go for the Konigsport then, because of the Koni shocks
