From Audi 100 to urS4 in a week
  • hunker7
    • Mar 2014
    • 3487
    #406
    Originally posted by bikerjim
    Good luck pal. I know only too well the rush of having to get car stuff done around uni. Stick with it.
    Thanks buddy. I was thinking how lucky i was that it happened at low speed.
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • hunker7
      • Mar 2014
      • 3487
      #407
      It's just getting worse. Noticed that PS fluid cooling pipe is corroded and leaking badly.
      '93 Audi UrS4 Avant
      • A1QSHIP
        • Aug 2004
        • 975
        Welcome to "While you are in there".
        "Nulla tenaci invia est via"
        • hunker7
          • Mar 2014
          • 3487
          #409
          Audi wants £100 for it, hope i can find a replacement cheap.
          '93 Audi UrS4 Avant
          • Majorcina
            • Jun 2013
            • 1334
            • Country: Montenegro
            #410
            Is it normal in UK that car have that much rust?Over here we dont have any problem with rust?At least not bad like i saw here on UK cars
            • hunker7
              • Mar 2014
              • 3487
              #411
              Thinking the same thing. My A100 was solid as a rock. Here rust is everywhere. Must be due to high humidity
              '93 Audi UrS4 Avant
                It because over here the roads are covered in rock salt for 4-5 months of the year
                • hunker7
                  • Mar 2014
                  • 3487
                  #413
                  In Latvia, we have salt too and rust isn't even close to that bad.
                  '93 Audi UrS4 Avant
                  • Majorcina
                    • Jun 2013
                    • 1334
                    #414
                    Probably thats it Error,when i saw some rust problems with cars on forum i checked my car below for rust,but no signs of it
                    • hunker7
                      • Mar 2014
                      • 3487
                      #415
                      I think a lot of people will be very happy that I have found the problem, because I've been quite a big pain in the ****.
                      This is the tool we made up, first one we did yesterday didn't work, but this worked like a dream.
                      Also got new parts today
                      And this is the *astard that caused all these problems (mostly). It was completely sheared off.
                      If I would buy another 2.2 20v I would replace the pulley straight away, and suggest anyone who buys 2.2 20v to do it. I was so lucky it happened at low speed, rather than when travelling 30 mph or more.
                      '93 Audi UrS4 Avant
                      • Majorcina
                        • Jun 2013
                        • 1334
                        #416
                        So car is working properly?Boost's like it shud?
                        • andy10v
                          • 5996
                          Lucky
                          Glad you found something though, you should be feeling happier again, now you have something you can physically sniff.
                          Sold ABY-stock
                          • hunker7
                            • Mar 2014
                            • 3487
                            #418
                            I just took the pulley off mate Got work tomorrow, will be putting it back together on Sunday. Still need to find the cooling pipe that's got a fockin hole.
                            Originally posted by andy10v
                            Lucky
                            I am a bit happier. When I start it again, and it runs OK that's when I will be HAPPY!
                            '93 Audi UrS4 Avant
                              #419
                              Hunker - you are one lucky guy... but I have to admire your patience there. Well done making that tool for the job and great result. Glad you took the collective advice here - now can you name and shame the professional monkeys who supposedly changed the belt 10k miles ago ??? You had a very near escape there... Hopefully you are seeing full boost again - thats 2.1bar on your digital gauge on that AAN. Good stuff !
                              • hunker7
                                • Mar 2014
                                • 3487
                                #420
                                I am indeed. Belt has been done 10k ago, just didn't do a good job of it.
                                I hope to get it on the road Monday latest.
                                Is it ok to fit that cooling pipe from A8 V8? It is shaped differently, but should do they same job shoudn't it?
                                '93 Audi UrS4 Avant
