Urs4 2.2T litle project
  • Dima ABY
    • Sep 2013
    • 183
    • Home: Ukraine Current: Spain
    #391
    Originally posted by Horsty
    remember that you better not bolt the a8 brake booster flat to the 80's spacer.
    Thats true!
    Need some mods.And to drill two new holes.
    • Majorcina
      • Jun 2013
      • 1334
      • Country: Montenegro
      #392
      I am not sure are you guys talking abouth C4 chassie or B3/4?
      • Dima ABY
        • Sep 2013
        • 183
        #393
        Urs4/6 and s2 have same brake servo.
        • Majorcina
          • Jun 2013
          • 1334
          #394
          I think i read when rs200(forum member) writed that it bolts straith up?I dont think he mentioned drilling holes.But in other hand,i might be wrong(that wouldnt be the first time )
          • Dima ABY
            • Sep 2013
            • 183
            #395
            Brake servo studs:
            Hidraulic Urs4/6,s2 - O O
            Vacuum a8,s8- O
            O O
            • Dima ABY
              • Sep 2013
              • 183
              #396
              Ahhh.
              Wonder to show you the position by "O" marks but was imposible .
              • Majorcina
                • Jun 2013
                • 1334
                #397
                Well bouth the rears also from cayene turbo s
                Will need Thomas's rear adapters also but this one's will need to wait some time to fit
                not the best photos but you get the point
                • ringbearer
                  • Sep 2011
                  • 176
                  Great pic for those with the rare foot/caliper fetish
                    #399
                    Originally posted by Majorcina
                    Can I ask what springs and shocks are on the silver UrS6 Avant ?
                    Also what springs are on your own UrS4 Avant ?
                    What size tyres are on both cars ?
                    Thanks for replies.
                    Avus rims and black coloured callipers.
                    • Majorcina
                      • Jun 2013
                      • 1334
                      #400
                      Hahaha i just wanted to show how big they are hehehehe
                      Abouth silver audi,he has stock shocks,-40mm springs and 235/40r18 tyre
                      On mine are 2 way bilstein shocks, -50 front and -40 rear h&r springs with 225/40r18 tyre
                      • Majorcina
                        • Jun 2013
                        • 1334
                        #401
                        Collecting parts for brake upgrade,till now bought
                        Front disc zimmerman 360x34
                        Read disc textar 330x22
                        Rear pads TRW
                        Ordered front pads brembo
                        Ordered Thuppu's front and rear adapters
                        Also buyed new battery,varta
                        • priba
                          • Mar 2015
                          • 108
                          • Country: Croatia
                          #402
                          if we're talking about c4 vacuum booster ...
                          front two bolts holding a master cylinder are horizontal
                          ..o.....o..
                          bolts holding a booster on the bracket form a square
                          ..o.....o..
                          ..o.....o..
                          comparing A/S8 booster, it has 2 bolts holding cylinder and booster onto the bracket
                          positioned like this
                          ..o........
                          ........o..
                          I've talked with rs200 some time ago about this and he told me too, no drilling required
                          not sure about hydraulic booster but the bracket should be same
                          I'll go to take booster from my scrap A8 today/tomorrow and make swap in a week so I'll let you know
                          • domas
                            • Oct 2014
                            • 307
                            • Country: Lithuania
                            #403
                            didn't read the whole story, but my point is that when doing vacuum booster conversion, change the whole kit, booster+master cylinder+fluid tank.
                            I have went with double chamber booster from A8, together with its cylinder and reservoir. There was a gasket that had to be fabricated behind it, but I am not sure which. It was not me who was doing the conversion. Keep in mind that I have done it on my 200 20v, which may be different from urs4
                            • Majorcina
                              • Jun 2013
                              • 1334
                              #404
                              Priba,i will wait you to finish it and maybe next week i will start my brake upgrade
                              • priba
                                • Mar 2015
                                • 108
                                • Country: Croatia
                                #405
                                here you go bro
                                some pictures from today's work
                                I forgot that I sell master cylinder few years ago
                                however, I found out it was A4/A6 m. cylinder since it had tank connections on top not at side, so I would have to buy a new one anyways
                                bracket
                                original vacuum brake booster
                                A8 vacuum booster
                                I've tried to place them in the position they should sit in the car
                                as you can see, only diagonal holes should be used to bolt the booster/cylinder
                                distance fits ... 102mm so does the hole
                                you can use original A8 bolts (don't forget to take them with you)
                                there is another issue
                                lenght of the shaft should be 230 mm for c4 and that you can't get without extending it with some kind of insert
                                as you see on the pic. I barely made it to 205mm with c4 fork on it
                                and what domas said, there might be a clearance issue between booster and the bracket
                                check the pic, see this "gold" bolt?
                                it is sticking out 2mm so bare in mind that booster won't sit on the bracket
                                it could get a bit shaky and you could get water inside your car
                                I'll grind them off and use some sealant over that white gasket
                                I had to stop for today 'cause of rain
                                more to come end of week
