Urs4 2.2T litle project
  • Majorcina
    • Jun 2013
    • 1334
    • Country: Montenegro
    #406
    Thanks brother,unfortunently i miss 1 bolt from A8 bomb,but i will find it somehow.I cant wait for you to finish it so i can see how much work will i have.I need to finish it in 1 day since its my daily and i travel evryday on work with him now
    • priba
      • Mar 2015
      • 108
      • Country: Croatia
      #407
      ah yes, I forgot
      taking off that 4 nuts underneath steering wheel is PITA
      yes, you can do it in a day but you have to have all the things needed
      • diesel des
        • 3896
        #408
        I hope you have more luck with the a8 setup on your c4 than I did. I had a total of 5 of these servos and not one worked. Before you fit it suck on the vacume pipe with master cylinder fitted to see if servo holds vacume. None of mine did. I ended up fitting a c4 tdi vacume servo. Problems resolved.
        • M_GORDON
          • Oct 2008
          • 1295
          • Home: Isle of Man Current: Vatican City State
          #409
          Hi.
          Very good job. The car is the prettiest Audi for me (well, I preffer a sedan but) and your work is awesome. But the A5 rims are very ugly and the IC outside of the bumper...
          PS: on your country isn't the MOT?
          Here brake changes, IC changes, Bumper cuts and all the things are illegal and we must paid for them (and not all is possible to pay)
          photobucket SUCKS
          • Majorcina
            • Jun 2013
            • 1334
            #410
            Hello Gordon,
            The rims are sold long time ago,avus are still on the car and will be for some time.Abouth the IC,i like it this way.It stands up in the crowd and looks more agresive(in my opinion)
            We have year registration which are high for car's like this,i didnt have problems becose the IC dont stick out of the complet bumper so it can past like this(even the police is giving me sometime a hard time)
            • Majorcina
              • Jun 2013
              • 1334
              #411
              Thuppu's adapters arived today,so happy with the quality of them.
              Now only braided hoses need to arive so i can start the upgrade
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                #412
                i remember someone locally has done the vacuum booster conversion.taken the booster from from a scrapped 2002 passat Tdi.the bolt pattern on the booster that being mounted on the firewall is diagonally with only 2 bolts same as on the A8's.only thing to be worried about is the brake reservoir cap clearance between the stock strut bar.I personally had done the A6 single diaphragm booster on my UrS6 before.Anyone knows if the A8's booster is 1.5 or dual diaphragm booster?if it's dual diaphragm,it would need to save more quids to complete the conversion.i had done the dual diaphragm booster on my Merc and been happy with it ever since.
                one of a few I5 from Asia.
                • priba
                  • Mar 2015
                  • 108
                  • Country: Croatia
                  #413
                  back on booster conversion
                  Marko, here's what I just did
                  first let me tell you that screw on the strut is metric so you can't get the nut in any hardware store
                  so I took the end part (fork) from A8 booster, cut it and used the screw on part as extended nut
                  than I needed a part of the bolt for extending the strut ... bolt from b5 suspension came in handy
                  it ended up like this ... 230mm overall length
                  use both securing nuts to fix everything properly
                  than I grinded off those two bolts for fixing the booster
                  and overall it looks like this
                  put some self adhesive insulation on the bracket
                  I used one for doors/windows ... it's soft and can be compressed
                  putting dual diaphragm booster in is way easier than taking old one out
                  I still didn't go to Igor (RS200) to pick up master cylinder and tank to end DIY but I think you'll be able to figure it out from here
                  cheers
                  • Majorcina
                    • Jun 2013
                    • 1334
                    #414
                    Thanks Priba,you will probably finish it before i recive the braided hose's so i can see evrything together
                    • Majorcina
                      • Jun 2013
                      • 1334
                      #415
                      Some small progres until all part arive
                      • popdemonic
                        • Dec 2007
                        • 1304
                        • Country: Thailand
                        #416
                        Marko,
                        You used the hair dryer to dry out the Porsche decal?
                        • Majorcina
                          • Jun 2013
                          • 1334
                          #417
                          Nah,i dont know why i took it ,i didnt even use it ahahaha
                          • hunker7
                            • Mar 2014
                            • 3487
                            #418
                            When I put "quattro" sticker on my calipers I put couple of clear coats to make sure it doesn't wear off.
                            '93 Audi UrS4 Avant
                            '15 Audi A7 quattro 3.0 TDI
                            • Majorcina
                              • Jun 2013
                              • 1334
                              #419
                              Done and done
                              • popdemonic
                                • Dec 2007
                                • 1304
                                • Country: Thailand
                                #420
                                cool!
