Audi S2 Track Torpedo from PL
Picture of the new front (part 1). Tomorrow another dyno tuning
In the last 3 weeks the work on the car was:
- new front strut tower bar
- Torsen for the front axle in 01E gear box
- new bigger intercooler ( 600 x 300 x 100 mm )
- bigger air inlet in front bumper
- new short pipes form turbo to IC and form IC to throttle
- swirl tank with new pump (Bosch 044 + 040)
- new stronger pressure plate in clutch
- stronger wastegate spring
Swirl pot
Last edited by Albert; 1 September 2014, 12:01.AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.netComment
When the fuel was around it 1/2 tank and on the fast corner (100-120 km/h) the fuel pump made specific noise. The same noise it is making when there is no or very little fuel. It happen to me a few times so I decided to fix that problem so I won't happen again. I don't want to loose the another engine
When is it time for a bigger turbo?
TWINCHARGED power,zero lag
AEM W/M injectionComment
witch turbo in the future?audi coupe quattro b2 2.2 20vt project (573hp-626nm)
Gtx3076rAKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.netComment
nice,i use a gt3076r with 0.82 A/R,great turboaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
Yup
good luck with your modifications
New dyno plot. new numbers are 410 HP / 458 Nm !
I all depends on you power
There is a mod that seals the stock diff in rear in higher speeds also. This will defiantly help. http://www.s2forum.com/forum/showthread.php?t=56997
