And finally, my RS2.
  • irishs2
    • Apr 2009
    • 2455
    Originally posted by mackenzie50
    Haha- some truth in that I'm afraid.....sales of Waxoyl must be higher here though!
    Very true, my Avant project is a Scottish car. Pity my previous owner didn't use waxoyl though.
    Eric
    95 S2 Avant under rebuild.
    • Nick320
      • Nov 2013
      • 52
      • Home: Bulgaria Current: Canada
      #122
      All this rs2 cars. Now i want one too.
      • cardcrash
        • Oct 2009
        • 763
        • Home: England Current: Wales
        #123
        Maintenance day at the Simmonds garage
        Went down to Kit's yesterday as he carried out some of the projects on his RS2 refresh list so I took a few pictures:
        Here is the rear off-side hub/brake caliper:
        Action photo as removal begins:
        More action with penetrating lubricant at hand:
        Action heats up some more as more leverage is gained by facilitating access from beneath the vehicle:
        And it's off, incredible! And in not too bad nick it would seem:
        The hub minus disc & caliper:
        Work now shifts to the nears side:
        Kit using the contorting skills he learned when he was an orphan on the streets of India:
        Kit is now using fire as a tool, specifically a turbo-flame soldering tool. I bring in my dog Holly to supervise and ensure safety is maintained at all times:
        A nice close-up action shot of the fire tool in use:
        Another caliper off, again in not bad nick plenty of pad left:
        Rear nearside hub minus disc & caliper:
        Here is a front nearside hub that was dealt with earlier:
        And a front disc, whilst the rears were good the fronts had some bias towards the outside:
        The front calipers:
        Whilst some of this was going on Kit set me to work on rejuvenating his sacrificial cat protection brackets which had been used as jacking points and were all bent with rough edges, I failed to take a before shot but here they are now a bit straighter. For doing this Kit has given me 50% ownership of the car:
        You're welcome Kit
        ...and meet Holly who did a great job supervising much of the works that went on and even dispatched a spider or two:
        Right, I'm back off down to Kit's again now, maybe some more photos later...
        RS2 - Project Mental Wheels
        RS2 - LHD on the road again
        RS2 - reduced to component parts
        RS2 Saloon replica
        A4 1.8T
        BMW 320d Touring M Sport Business Edition auto
          • 4754
          • cardcrash
            • Oct 2009
            • 763
            #125
            Spent yesterday cleaning Kit's Brakes which were quite grubby:
            Kit removing the springs using his magic fire pen:
            Clean(er) front calipers:
            The rears:
            All the while Kit was tackling his fuel pump:
            Fuel Lines shot:
            The tank:
            The tank supported by a block of wood:
            Some progress being made with fuel dripping into an empty Nescafé Azera Americano instant coffee tin, a fine instant coffee if ever there was one!!
            The slightly sorry looking tanks straps:
            ...and that was about it for the day. I'm still a bit dizzy from the brake cleaner fumes!
            RS2 Saloon replica
            A4 1.8T
            • LHD_Kid
              • May 2006
              • 3696
              #126
              Great work and really good write up and pics.
              You sure Kit wasn't grabbing 40 winks in the boot while you were busy cleaning up his calipers?
              • K Simmonds
                • Dec 2007
                • 7627
                Nice one for posting all the photo's mate, I'm terrible at remembering to take any myself.
                In summery the plan of action here is a full brake service, and I mean full! Fit a pair of new track rod ends/bottom ball joints as well as drop links and whilst the car is off the road over the pit tackle the joyous task of changing the fuel filter.
                Oh yeah and I've fitted a better replacement NS damper along OE top mount's/mount savers and better bump stops both sides. I'm going to be having the original springs from Charlie's Mental Wheels project at some point so for now the brake's take priority.
                The rear callipers desperately need refurbishing so their going to be off to Bigg Red in Worcester most like along with the fronts as if I have them done now they should come up really well.
                Front disk's are going to be skimmed by the same mate the did my flywheel, their hardly worn just the inside faces are a bit grotty. New Mintex pads have been ordered.
                The rear discs and pads are like new as are the handbrake shoes and mechanism so the that'll be serviced and everything cleaned and reused.
                I dropped the tank to get better access to the filter as well as de-rust and Por15 the retaining straps.....
                I've all but given up trying to undo the 5m head Allen bolt that retains the filter, I can't stop the nut on the other side from turning given the poor access. Though I'm going to have one more shot at it before I admit defeat and cut through the bolt with hack saw blade. As far as I can see it looks like the original filter..
                I have a new genuine Audi item waiting on the shelf where it's been sat for the past year, knowing it was going to be a sod I've been putting the job off. I'm also going to remove the fuel pump and clean the strainer out for good measure.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                • cardcrash
                  • Oct 2009
                  • 763
                  #128
                  There were sporadic swear words emanating from the pit throughout the day so I'm sure he was up to something!!
                  RS2 Saloon replica
                  A4 1.8T
                  • cardcrash
                    • Oct 2009
                    • 763
                    #129
                    Originally posted by K Simmonds
                    I'm going to be having the original springs from Charlie's Metal Wheels project at some point so for now the brake's take priority.
                    "Metal Wheels"????
                    RS2 Saloon replica
                    A4 1.8T
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      Originally posted by cardcrash
                      "Metal Wheels"????
                      Sorry...... 'Project Mental Wheels'....it was your choice of name.
                      1994 MTM RS2.
                      2000 B5 TQS.
                        • 4754
                        "Metal Wheels"????
                        That was my reaction,it seams being under the car has strained his
                        mental abilities to the limit! God help him with a cut roof.
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          Oh dear
                          I see the mistake now and I've edited, I'm Dyspraxic so I struggle with words and spelling a little, I'm basically retarded.
                          1994 MTM RS2.
                          2000 B5 TQS.
                            • 4754
                            Kit, .. .. you should have said shut the f**k up London! However if your dyslexic we'll pray for you so your less afflicted.
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              After the fumes we breathed in yesterday I was struggling to do anything more technical than operate an Allen key in a confined space and swear a lot.
                              Forgot to add I need to make up a couple of new hard-lines for the brakes, the N/S/F strut to calliper pipe wouldn't free up even after lots of heat and mole grips so it got twisted. The O/S/R calliper feed pipe snapped as soon as I moved the spanner, the wall was paper thin in place's so I'm glad I found it, the other side has already been replaced and didn't cause any problems.
                              Oh yeah and I'm going to clean and Waxoil the fuel lines, their currently pretty dam good and it would be nice to keep them that way.
                              1994 MTM RS2.
                              2000 B5 TQS.
                              • K Simmonds
                                • Dec 2007
                                • 7627
                                Fortunately Dyspraxia isn't quite as bad as being Dyslexic, it's about two rungs down on the internationally recognised mong/spaz scale
                                1994 MTM RS2.
                                2000 B5 TQS.
