80tq: 516whp
  • ottawa coupe
    • 851
    500+whp....dude, you just blew my mind
    1993 UrS4...aka the rocket powered living room
    • JSHADZI
      • Oct 2004
      • 66
      Originally posted by auditude
      I bet his answer will be that he'll stick with it as long as it's not a restriction. Once it becomes the bottleneck, then it would get addressed. Am I right, Javad?
      That is correct...I hear so many people talking about the need for a better IM w/o citing any good reasons...guess we still don't have any yet??
      Javad Shadzi
      www.034motorsport.com
      www.80tq.com
      • auditude
        • 407
        I think the "FMTB" intake manifolds probably help more with throttle response than they do ultimate power levels. They can fit the available space better, after moving stuff around, and don't require the intake to go past the hot turbo, but obviously those issues don't preclude making big power using them.
        I have heard people say the AAN type IM might not flow as well to cylinder 1 tho'.
        Kenneth
        1990 Coupe quattro
        1991 200q20v x 2
        1985 4ksq 20vt project
        1986 Coupe GT 10vt project
        2006 Honda Ridgeline
        1998 Honda VFR800FI
        • sorens2
          • 241
          • Country: Denmark
          My BOV had a stiff spring when I bought it. Replaced it to a much softer on. But the lag is huge now...
          Søren S2
          Audi RS4 LO550
          BTG 8:08
          www.fredslunds.dk
          • JSHADZI
            • Oct 2004
            • 66
            #20
            Agreed about the packaging concerns, no argument there, that's not what I was addressing.
            With that said, I haven't seen any conclusive evidence to show actual throttle response is improved, I consider that more a theory than anything, anyone have conclusive evidence?
            Javad Shadzi
            www.80tq.com
            • JSHADZI
              • Oct 2004
              • 66
              #21
              Søren S2
              Well, it sounds like your valve is opening under boost? That is not correct, if there is pressure to the top side of the valve it should not open prematurely.
              Javad Shadzi
              www.80tq.com
              • sorens2
                • 241
                • Country: Denmark
                #22
                It doesn´t open until I lift off the trottle. Car pulls as always and there is no leaking sound. And it makes that nice whhooosss sound as it should. Still lots of lag. Used to have a small Bailey. Worked ok.
                Søren S2
                Audi RS4 LO550
                BTG 8:08
                www.fredslunds.dk
                • auditude
                  • 407
                  Yeah, no argument here either. I have a FMTB style IM because at the time I didn't have any regular ones. Now that I have it, I'll use it (someday, that is!).
                  On the throttle response thing, I think some folks on here have reported it being improved after hacking and rewelding an AAN type IM into the (MTM/SQ style) FMTB configuration.
                  I'm kinda curious what factors influence throttle response. It seems like decreasing the distance between the TB and the turbo might help, but what are the influences on throttle response? (just a general question for whoever)
                  Kenneth
                  1990 Coupe quattro
                  1991 200q20v x 2
                  1998 Honda VFR800FI
                  • audiman
                    • 4827
                    We have proved that the FMTB IM reduces the revs that the turbo hits in, but only by about 4-500rpm.
                    Javad, great figures dude. Would be worth doing a back pressure test IMO too. I used to run a 2.5" DP, but that casued the car to pink at about 5k, then i changed to 3" DP and the pinking was gone, this was because the gases could just get out faster (less back pressure). Ask Mihnea, as you know he does my mapping.
                    I also run the stock 3B manifold and it ISNT a restriction
                    Tom C - www.rcmr.co.uk
                    Audi UR Quattro
                    Audi 100 C3 2.0 5 cyl 115ps
                    Audi B5 RS4 645ps 911nm
                    • audiman
                      • 4827
                      ****** i meant to ask what the part number was on the plugs that you are using and the gap on them. Im getting the odd misfire with the original AAN bosch plugs, it might be the coil dying, but if you found misfire probs then it could be the plugs causing it.
                      Audi UR Quattro
                      • JSHADZI
                        • Oct 2004
                        • 66
                        #26
                        Most of the time when I see someone upgrade their IM, it comes will all sorts of other upgrades at the same time, I'd love to see someone who did this experimentally, I plan on doing this eventually.
                        Factors that I've found increase response in turbo applications:
                        -free flowing airfilter and inlet tract
                        -smaller turbo
                        -cams w/o any overlap
                        -free flowing cylinder head
                        -free flowing exhaust
                        Javad Shadzi
                        www.80tq.com
                        • JSHADZI
                          • Oct 2004
                          • 66
                          #27
                          Can't remember off the top of my head, but the standard 2.3l 20v plug, code 7A, tri-electrode, don't need gapping.
                          Javad Shadzi
                          www.80tq.com
                          • audiman
                            • 4827
                            The other thing that i noticed that improved response was to move the MAF (if fitted) to the pressure side of things. But wouldnt recommend doing it, unless you have to.
                            Audi UR Quattro
                            • audiman
                              • 4827
                              F6DTC in BOSCH
                              Audi UR Quattro
                              • JSHADZI
                                • Oct 2004
                                • 66
                                #30
                                Great! Do you have any documentation you used to come to your conclusion? I'd love to see what you used for evaluation (not that I don't believe you, but that I may come to the same conclusion as well ).
                                Javad Shadzi
                                www.80tq.com
