Project fast S2 to faster S2 - Australian Edition
  • #31
    Good point.
    I wanted to make up a box for the filter however i cannot get a 4inch bend off the front of the turbo so instead i will make up a heat shield to block it off.
    Will still work the same
    Current:
    1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
    Past:
    2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
    2001 Audi S3 Silver - 169kw+ atw
    • #32
      You could try a cobra head hose
      • #33
        Waiting for results.
        Audi S4 2.6 20V STROKER kkk26/27
        • #34
          Now that you mention it i have seen them. Maybe a will look into it
          Current:
          Past:
          • #35
            Same here!!! [emoji51]
            The run in period is frustrating.... lol
            Current:
            Past:
            • #36
              Run in period is finally over
              Only 32psi
              Thats 580hp atw
              And roughly 770hp at the crank
              Rev limit set at 8000 cause peak hp is at 7800
              Current:
              Past:
              • #37
                Thats some nice numbers!
                Well done!
                • #38
                  Yes i am very happy.
                  And very reliable power too!
                  So cant ask for more than that
                  Current:
                  Past:
                  • #39
                    Mate that looks awesome. So good to see it finished
                    Can I buy it back now please??
                    Karl
                    Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
                    Audi 90 Quattro 20V 1989 7A
                    Audi TTRS 2010 APR stage 2 +
                    Triumph 675 Street Triple R
                    • #40
                      Nice! But what dyno did you use? 190hp drive train loss seems a lot?
                      • #41
                        I just work on roughly 25% losses though drivetrain and quattro
                        Current:
                        Past:
                        • #42
                          you have a video?? sure it sound like a beast
                          Step 1: setup. <==
                          Step 2: potentiation.
                          Step 3: enjoy.
                          • #43
                            Dyno is a dual roller mainline dyno
                            See another graph i just received.
                            Power comes on later then i hoped with the gtx3582
                            Wondering if its just my higher lift cams pushing all the power to the right, or whether this turbo with 0.82 rear is not suitable.
                            Or if in fact a need a shitload more timing
                            Full boost isnt seen until 6000
                            Roughly 20psi at 5500
                            And 10psi at 4800
                            Current:
                            Past:
                            • #44
                              That'sa bit laggy eh mate? Maybe the turbo would be better with the .63AR?
                              Could it handle more aggressive timing at the lower revs?
                              Still amazing power mate
                              Karl
                              • #45
                                Oh its fun when you are in the rev range, lol but yeah kinda late.
                                I considered the 0.63 but i fear it will choke up way to earlier and im going to lose a lot of power.
                                Timing wise is still conservative, and i think i can go a fair bit more.
                                Once i sort out the breather setup its going back for a full day test and tune
                                Current:
                                Past:
