Colesy's WR Quattro
  • Skull
    • 3506
    • Country: Slovenia
    How many volts do the fuel pump get with the engine running? Could be running lean...
    Audi Quattro WR
    • Colesy
      • Feb 2009
      • 2980
      Judging by the plugs after a few hours use I'd guess it's not running lean:
      • Skull
        • 3506
        • Country: Slovenia
        than you have to start from the beginning, checking the system and control pressure, replace all the vacuum hoses, check if the idle and WOT switches work correctly, if the rotor is the correct one... and so on
        Audi Quattro WR
        • adam g
          • Feb 2007
          • 445
          This really sounds like an air leak to me, have you pressure tested for this yet?
          Sent from my D5803 using Tapatalk
          • Colesy
            • Feb 2009
            • 2980
            Have made quite a bit of progress with this, contact cleaner has been an absolute saviour!
            The window switch and the dodgy digital dash just needed the contacts cleaning and now are working perfectly. The radio just had to be plugged in at the battery. It is also running much better having cleaned the air temperature sensor on the IM.
            A boost leak test is next on the list which might improve it further.
            It's great to be able to take it for a drive and actually know the revs and speed I'm doing now!
              Nice one mate, they're nice to drive aren't they?
              • Colesy
                • Feb 2009
                • 2980
                It is great to drive, I do miss the extra HP of the S2 at times though.
                Must resist the urge for extra power!
                  Colesy's WR Quattro
                  Has it got the ECU mod and WG spring wound down?
                  • Colesy
                    • Feb 2009
                    • 2980
                    The WG spring has been wound down so I would assume that the ECU mod has been done too, haven't had a look inside yet though.
                    It does go well, I'm just used to ~380 in the S2 which trounces almost anything.
                    Had a van come up behind me yesterday which I couldn't shake off...
                      Yeah, in stock form with the spring and mod they have a nice midrange push but nothing up the top end. Treser big valve head, more fuel and hybrid turbo helps [emoji6]
                      • Colesy
                        • Feb 2009
                        • 2980
                        Have been doing some boost leak testing! The biggest leak found so far seems to be coming from the throttle body shaft, on the cable side...
                        Can the seals be replaced does anyone know?
