S2 avant
  • Mikes2
    • 1704
    Think my 90 20v has a Graf in it just now.
    yes - that was my car at Skidz
    Mike
    http://www.s2-audi.co.uk
    • John.
      • 2615
      Your 90 is a quattro Mike...yes?
      I remember you telling me Graf pumps have a metal impellor so I assumed you've fitted one.
      • Mikes2
        • 1704
        It's a 20v quattro sport
        Mike
        • John.
          • 2615
          ......thanks.
          • Mikes2
            • 1704
            It's been a while since I updated this. Only done about 4000 miles since the last MOT. The tailgate had the usual corrosion around the wiper arm. Bodyshop removed the screen and performed a repair.
            Before :
            After
            Got a new wiper arm fitted at the same time as the old one wasn't holding the arm on the glass any more
            Mike
            • Nuvo
              • Nov 2003
              • 3825
              #96
              Repair looks good. What causes this to be a problem area on avants? Is it the leaking water from the washer jet rusting from the inside out?
              • John.
                • 2615
                That looks good Mike, does the bodyshop have someone "in house" that removed and refitted the screen or did they use a windscreen company do you know? Will have the same to do on my car at some point.
                • Mikes2
                  • 1704
                  can only think it's water ingress that causes it but it's very common. They used an outside company to remove the glass. There's no damage to any of the trims. You wouldn't know it had been disturbed
                  Mike
                  • quattro estate
                    • Aug 2015
                    • 190
                    Hi, just been going through your log of work you have achieved to date. Well done with your efforts.
                    with the pictures of the radiator and fan motor before you dropped them in, what are the two pipe like connectors for on the back of the motor. I've wondered when I saw them on mine....
                    keep up the good work.
                    • Mikes2
                      • 1704
                      Not 100% sure on this but possibly a cooling outlet for the motor
                      Mike
                        The motor can be water cooled.
                        • Mikes2
                          • 1704
                          Some of pictures may disappear temporarily as my hosting site is about to change. Bear with me as I move stuff around over the next few days
                          Mike
                            • Dec 2017
                            • 5991
                            Any progress Mike? I'm in need of an enthusiasm injection
                            • Mikes2
                              • 1704
                              Nothing has really changed. The car is taxed and MOT'd but doesn't get used much.
                              Mike
                                • Dec 2017
                                • 5991
                                That sounds a bit boring? Perhaps I'd better slow down a bit and relish the moment then?
