S2 Avant -93
  • Antsa
    • Nov 2016
    • 611
    Bonnet painted today. I'm going to wait for it to dry a few days and then sand it and re-clear. I'm starting to lose interest in painting outside paintbooth, the ammount of dust particles landing on freshly painted surface is just too much
    • Antsa
      • Nov 2016
      • 611
      Well the bonnet is now sorted, no pictures of it unfortunately. It came out ok, not 100% carshow quality but good enough.
      The head is at Kansiset to receive some mild porting and all other necessary head work.
      While waiting for the head to be finished, I treated myself with a brand new welder! It can do AC and DC Tig plus stick. I plan to weld the exhaust myself when the time comes. It also came in handy when rebuilding my gearbox.
      My first welding attempt was to make this gearbox casing separator using an old puller and some flat bar. Not pretty welds but the tool worked.
      The the 5th and 6th gear were pulled out, then the cast iron middle casing can be separated from the differential housing.
      5/6 selector fork can the be taken out followed by input shaft, 3/4 and reverse selector.
      Then the reverse gear can be removed and the hollow shaft can be pressed out
      This is the whole gearbox disassebled
      The reason for this rebuild is that when fast shifting to 2nd gear I would get gear grind. Synchro rings or the synchro hub was my guess for fault. The 2nd synchro has seen better days.
      • YELL MAN
        • Dec 2005
        • 535
        • Country: Shetland Islands
        #408
        Pretty scary task, I need to the same as my box has the same issues, swapped to a spare but want to get my original back to working condition
        1994 Indigo Blue S2 coupe
        1994 80 Avant 1.9 TDI
        2005 Yamaha Fazer 1000
        1953 AJS Model 18S
        • Antsa
          • Nov 2016
          • 611
          I purchased a rebuild kit from JHMotorsports, it comes with all seals, updated 1-2 synchro hub and all synchros and springs.
          Then it was time for rebuild. I started with placing the tapered rollers on the pinion shaft. Vaseline helps here.
          All shafts were put together and istalled in the housing.
          Then the middle casing was installed back onto the front diff housing and then rest of the gears were put in. I made a mistake when installing the 5/6 synchro hub on the input shaft by putting it the wrong way round. Once the shaft was fully assebled the mistake caused the gearbox to lock up on some gears. After a bit of thinking and reading through the manuals the mistake was corrected and all gears can now be selected and shafts can be rotated while in gear.
          Tomorrow is time to install the rear diff housing, change the output flange seal and put in the output flange. Then it's just a matter of changing the input shaft seal, putting the selector shaft and it's cover back in and that would complete the gearbox rebuild
          • Antsa
            • Nov 2016
            • 611
            Surely feels like that at first, but with a well documented youtube video by JHM and a factory manual, it's not too bad. A few pullers and bearing puller plates and hydraulic press is needed.
            • Antsa
              • Nov 2016
              • 611
              Gearbox now finished. There will be a small break from updates due to a small holiday trip and then back to work! Next time I hopefully will begin the engine build.
              I found a small section of 3" stainless pipe and had to try out my tig. Still a lot to learn, but I think a downpipe can be done with some practice.
              • Antsa
                • Nov 2016
                • 611
                I guess this is the best part of any project, putting the engine together! I started with a wash and brushing all oil channels. Glad I did, there was a fair amount of crud in that I don't want on my bearings.
                A new non return valve was installed
                Next was the oil squirters and new bolts installed with locking compound
                Then it was time to measure bearing clearances. First the crank main journal diameter is taken with micrometer and then locked. Bore gauge is then zeroed in the mic and installed into the main bearing housing. The indicator then shows oil clearance. I got 0,07mm which is just a little bit more than the manual says for new bearing clearance. But they say that no one will know if you have a little extra but everyone knows if you don't have enough
                I wanted to double check my readings with plastigauge. All good
                All bearings got assembly lube before installing crankshaft and then main caps torqued.
                Then oil pump and pickup tube
                Finally it was time to check crank end float. This is on the tight side of spec, just enough at 0.07mm. I think some of this is due to the very thick assembly lube that I used in the thrust washers.
                Then all pistons and conrods were assembled so I can continue tomorrow
                • rxl
                  • 1913
                  you need to put windage tray with one of the gaskets before the oil pick up tube goes
                  • Antsa
                    • Nov 2016
                    • 611
                    Yeah, I noticed the same when I picked up the oil pan gaskets today. Got too excited to bolt on parts that I had at hand
                    • Antsa
                      • Nov 2016
                      • 611
                      Pistons were installed today. This tapered install tool is really handy
                      All five in
                      Next I will take the engine temporarily out of the stand, install the rear main seal and correct my mistake with the oil pickup.
                      • Antsa
                        • Nov 2016
                        • 611
                        Another little update. Rear main seal installed.
                        Then I corrected my mistake with the windage tray and fitted the sump
                        Last time I see the pistons for hopefully a long time.
                        Head on with cams and adjustable belt pulley and chain sprocket. Also new INA water pump, made in China. It seems that many items that are approaching the end of their life cycle are being made in China. We'll have to see how long it lasts.
                        Then it was time to take the engine out from the stand and install the flywheel and clutch. Exhaust manifold also in place. Now I have some serious thinking to do regarding what turbo to choose. The limiting factor size wise is the RS2 Evo exhaust manifold. I understand that Gtx3071 size turbo with .63 exhaust housing should fit? All input about what turbos work with this type of manifold is welcome
                        • rxl
                          • 1913
                          looking realy nice.
                          • Antsa
                            • Nov 2016
                            • 611
                            A black box arrived
                            It contains a turbo!
                            Here it is fitted
                            It clooooose to exhaust manifold
                            A 10mm T3 flange used as a spacer sorts it. Now I can fit stock heat shielding around the manifold and wastegate and turbo doesn't hit the chassis rail.
                            But I have another problem, my clutch hits the bellhousing. I used the tried and tested blu tack to verify that I have no clearance!
                            This is s little troubling, since I have a single mass flywheel (no idea where it is from) and it should fit with a Sachs707 pressure plate without using the spacer between the block and gearbox Even with the spacer installed I get a very light rubbing. No idea where it touches inside the bellhousing, but I will continue investigating tomorrow.
                            My SMFW seems to be 40mm thick. Does anyone remember aftermarket ABY/ADU flywheel thickness or can easily measure one? I'm thinking that this might be flywheel issue.
                            • Antsa
                              • Nov 2016
                              • 611
                              Facebook group told me that SMFW's are not this thick usually. I still wanted to try if i could make it work. So I took the flywheel and pressure plate off the engine. Painted the inside of bellhousing black to make any scratch marks clearly visible.
                              Pretty obvious now where the contact is happening. I ground some material off the bellhousing but I didn't want to go too far. Pressure plate still makes contact so I'm in for a new flywheel.
                              Then I decided to cure my disappointment by drilling hole to the turbine housing! I tapped this to 1/8 npt so I can monitor exhaust back pressure or egt.
                              Here's just a quick trial fit. The copper piping will be modified after the engine sits in the car.
                              Now I will have to wait for the new flywheel to arrive and then give this another go. Hopefully then I can bolt the gearbox and engine together for good and put them in the car
                              • rxl
                                • 1913
                                turbo looks amazing. and it does not hit the rail? what power can it make?
