S2 Avant -93
  • Antsa
    • Nov 2016
    • 622
    It does not hit the rail, it's pretty close but doesn't touch. Maybe I will add a couple of shims under the right engine mount to raise it just a little bit.
    It's a precision 5558 turbo with a 55mm compressor inducer and it's advertised horsepower rating is 650hp. We will see how this turbo works once everything is ready for tuning.
    • Antsa
      • Nov 2016
      • 622
      I have an adjustable Tommi's Billet cam pulley. However it was not a direct fit. I had to grind it from several places so that it doesn't interfere with the cam sensor.
      This steel ring holding down the cam sensor wheel was too thick. I used an angle grinder to make it a little thinner. Also the bolts had to be shortened.
      Dremel and a sanding drum used here.
      Now it's better. I used a 0,2mm feeler gauge between the sensor and the wheel and it fits. I take it's enough clearance.
      New flywheel came. It weighs under 6 kilos.
      Installed
      Bolted the engine and gearbox together to make sure no rubbing of anykind is present anymore.
      The new flywheel does not have the TDC marking on the outer circumference. With the aid of a dial indicator and a degree wheel I set cyl 1 to TDC.
      Red marking pen and a scribe was used to make a new marking. Now it should be fairly easy to find TDC when I need to.
      Tomorrow will be a day to install the box and engine in the car!
      • Antsa
        • Nov 2016
        • 622
        The engine and gearbox are in! It took a few tries make it go in nicely but got there in the end. It would have been easier with left side engine mount removed but I thought of that after everything was installed.
        But now I have another problem to solve. The shifter linkage doesn't want to bolt on to the gearstick. It is also hitting the transmission tunnel. This might be because I renew the linkage ball bushing and I had to put a couple of washers under the right engine mount to give clearance for turbo.
        I will probably have to take out the engine and box, remove the turbo and put the engine and box back in without the washers under the engine mount to see if that is my issue. If that's the case, I will have to think of other measures to give clearance between turbo and chassis rail. I currently have a 10mm spacer between turbo and exhaust manifold, making it a 5mm might help.
        • Jaswan
          • Apr 2011
          • 774
          #424
          Looking good!
          If it were me I'd try it without the spacer between the turbo and manifold. That said, if there is no issue against the chassis when you remove the shim from the engine mount just leave it in.
          Well done on the work so far.
          Jase.
          • Antsa
            • Nov 2016
            • 622
            I will have to do some testing to see what works best. A little spacer between turbo and manifold has to be left. Without the spacer the compressor housing is too close exhaust manifold, about 1mm between them.
            I thought that I will just throw the gearbox and engine in and everything just would work Of course I should have known that changing one thing will have an effect on others. I guess I will have to do some more trial and error and remove and install the engine couple more times
            • Antsa
              • Nov 2016
              • 622
              After some trial and error with the shift linkage I noticed that reverse would not engage. I had to take the gearbox back apart to see what the issue was. Everything was assembled correctly, but I only could get reverse to engage if I spun the input shaft counter clockwise (engine spins clockwise). I could have modified the reverse gear synchro plate to make it engage easily, but I decided to set the reverse gear spring a little differently. It's hard to explain in words, but now I can get reverse to engage and everything seems to be good.
              Gearbox is now assembled and bolted back to engine and I'm back at setting the shift linkage. I think I have it all figured out now and with a days work or so, I should be good. Then it's just fitting the propshaft and driveshaft and then finally I can start making the exhaust.
              • Antsa
                • Nov 2016
                • 622
                Spent this day trying to make the shifter linkage work with no luck. It seems that I can't make the gearstick end of the linkage move like the gearstick moves I'm starting to run out of ideas.
                  • Dec 2017
                  • 6015
                  Don't despair. There must be a simple solution. Sleep on it. I've hit seemingly unfathomable issues many times and there is always a solution.
                  • Antsa
                    • Nov 2016
                    • 622
                    You are absolutely right, I will take few days break with the car. Fortunately work takes care of that. I will be back at it next week.
                    • Antsa
                      • Nov 2016
                      • 622
                      So my holiday started and I'm free to get some work done. Except that I got a cold. It's not too bad though and I could not resist to pay a quick visit to garage.
                      This shifter linkage issue is solved by new aftermarket one. It works a treat. If I had the patience I maybe could have made the original work. But I'm glad that this is now sorted.
                      I also wanted to install the heat shield betweed turbo and exhaust manifold. It reguired a little hammering but it fits now. Compressor housing is close to the manifold as is the turbine housing close to the chassis rail. We'll see if the clearances are enough.
                      Then I prepared to paint the propshaft. Only to find that rubber on the center bearing is shot.
                      So I split the shaft and painted it separately. Now I will have to find a new bearing.
                      • Antsa
                        • Nov 2016
                        • 622
                        Propshaft bearing ordered today and with luck I should have it tomorrow.
                        Paintwork done too. Epoxy followed by polyurethane.
                        Front driveshafts were installed
                        And I started I little mockup on the exhaust. The wastegate connection to downpipe will be a challenge for sure. I also should have welded the first section of pipe to turbo V-Band before mounting the turbo for good. Now the space is a little tight but should be doable.
                        • Antsa
                          • Nov 2016
                          • 622
                          Propshaft bearing now changed and shaft installed. This is the 4th(!) propshaft bearing I've got on the car now. When this fails, I will get a JXB bearing carrier.
                          Some more of the exhaust done. Still needs the section from cat to first silencer and wastegate to downpipe.
                          • ert
                            • Aug 2007
                            • 18
                            I guess the flex joint will be after the cat? If so then why not before?
                            I'm just curious because my cars exhaust has no flex joint at the moment but as the season is over I plan on putting one before the cat right after the 90 degree turn under the car. It will probably need an extra hanger though. To prevent sagging.
                            • Antsa
                              • Nov 2016
                              • 622
                              Yes, the flex will be after cat. I used to have it like that before without issues so I thought why change.
                              I will support the cat to the gearbox and since it moves together with the engine this should work.
                              I know there will be some thermal expansion between the downpipe and cat and without a flex it may cause problems. The cat support will have rubber isolators that shoud allow small movement.
                              This is how I thought it, but we will see if it works
                              • Antsa
                                • Nov 2016
                                • 622
                                Todays job was to make sure the exhaust tips sit nicely in the cutaway at the rear bumper. Well they didn't. The Jetex exhaust back box is too big and it hits the floor of the trunk. So I had to make adjustments.
                                I cut out a section of the silencer so it would fit better
                                Then I can weld the piece back in upside down. Hopefully I can finish this tomorrow.
