you got anymore pics of it looking sweet lost that copy of maxpower when i moved
10v NA FWD 5 speed gearbox
i'll borrow his photo album n scan em in at work if i rememberNautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management
The old Bus
0-60 4.9
1/4mile 13.5Comment
That would be Frank Shields Coupe GT.Originally posted by Baldyone of my mates built a 10v turbo type 85 coupe and he used the box from an A80 formel E in it . when the box was on the old 2.0 JS fifth gear was useless but when u put 280 bhp into it it pulled like a train and the top speed was off the end of the speedo round towards odometer it also gave nice mpg which is what the box was designed for.
the car looked pretty cool too
Never show a fool a half built house.
Never underestimate the power of stupid people in large groups.
Life is like a **** sandwich
The more bread you have, the less **** you eatComment
Couldn't have been Formel E box, as they were used in the Audi 80, the 4 cylinder bellhousing would not marry up to a 5 cylinder.Never show a fool a half built house.
the gearbox was from my audi 80 js engined formel e cos i swapped him for his coupe box car had the little eco gauge the button on the wiper stalk that stopped it in traffic and you could restart it by pressing by pressing both the accellerator and clutch together it gave 25mph per 1000rpm in top gearNautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management
The old Bus
0-60 4.9
1/4mile 13.5Comment
your talking out ur **** mate the 4 and 5 cly block are the same just an extra potOriginally posted by ~DeltaCouldn't have been Formel E box, as they were used in the Audi 80, the 4 cylinder bellhousing would not marry up to a 5 cylinder.
94 s2 avant
aoc member 1116
was gonna say i drove round usin the box till i bought mi white 90 quatt that you can see in background of the pictureNautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management
The old Bus
0-60 4.9
1/4mile 13.5Comment
Completely different blocks, more than just an extra cylinder. Early gearboxes were not interchangeable between 4 and 5 cylinder, untill the arrival of the type 89 cars in 1987, these boxes were only interchangeable because they had multi bolt fitment.Originally posted by pastures16your talking out ur **** mate the 4 and 5 cly block are the same just an extra pot
4 and 5 cylinder blocks the same, huh?
1) 5 cyl has 8 bolt flywheel, 4 cyl has 6 bolt flywheel
2) 5 cyl has cam driven dizzy, 4 cyl has intermediate shaft driven dizzy
3) 5 cyl lacks intermediate shaft, 4 cyl has intermediate shaft
4) 5 cyl has crank driven oil pump, 4 cyl has intermediate shaft driven oil pump
5) 5 cyl has cam belt driven water pump, 4 cyl has vee belt driven water pump
6) 5 cyl 20V has cams chain linked at front end, 4 cyl 16V has cams linked at rear end
7) 5 cyl has lower mounted alternator, 4 cyl has top mounted alternator
8) 5 cyl has hoop for starter motor, 4 cyl has no hoop for starter motor
9) 5 cyl has 2 upper bellhousing bolts, 4 cyl has 1 upper bellhousing bolt
There are other differences between 4 & 5 cylinder engines that will take up quite a lot of space, so we won't go there.
If any 2 VAG engines are the same, barring an extra cylinder, it's actually the inline 5 and the inline 6 in the old VW LT. The straight 6 is a development of the IL5, identical down to the cast marks and webbing on the block. The engine mounts are in exactly the same place, the PAS pumps are in exactly the same place, the oil pumps are interchangeable, the cam belts are interchangeable, the water pumps are interchangeable, the engine breathers are interchangeable, the rocker covers are the same design, apart from the length, the cam belt covers are interchangeable, in fact, everything not affected by the length is interchangeable between the 5 and 6 cylinder.
Both engines used the well proven 016 tranny.
The only thing the 4 and 5 cylinder engines have in common is the dimensions of bore / stroke, conrods, spacing between cylinder ports (inlet and exhaust) and of course, the trade mark right inclined slant to the engine.
It almost seems a shame Audi never developed a petrol turbo version of the straight 6, or even a multivalve cylinder head, making it a nice 24V unit. Add 2 turbos on each 3 branch exhaust manifold, we have a configuration pretty similar to a Skyline. Shame it's so bloody long...
So Pastures, we learn a new thing every day, insulting me for making a contribution you don't agree with certainly isn't clever.Never show a fool a half built house.
franks own words from feature in audi owners club news letter issue 10 june 1998
full featureAttached FilesNautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management
The old Bus
0-60 4.9
1/4mile 13.5Comment
My apologies Baldy, I remember Audi had 2 5 cylinder models in the type 85 saloon - 80 quattro (2,144 cc KK) and 80 CD (1,921cc WN and 1,994cc JS). The CD had the 4 + E tranny, though it was not actually badged as Formel E. (Formel E was a model in its own right with econometer, as in early WN - engined Coupe GT-5S).Never show a fool a half built house.
lol np
read the feature its pretty coolNautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management
The old Bus
0-60 4.9
1/4mile 13.5Comment
Ah! (Nickel drops) Baldy, are you Peter Humphries, I was chatting to you and Frank, I think your 90 q was a nitrous assisted car, if I'm thinking of the right person...
