Hi, does anyone have a big torque wrench i could borrow to do the cambelt?
Torque wrench
Tags: None
Is there an agricultural engineer anywhere near you? That's where I borrowed mine from and cost a pack of beer
Urs6 plus project goneComment
This one just makes it if you are still struggling. It just short of the recommended torque or you could do 200nm plus 180 degrees. I have two of the smaller Teng wrenches and they are nice.
https://www.screwfix.com/p/teng-tool...3-4-x-33/58074
I was thinking of getting one of these. If you can't borrow one I might be interested it buying it from you after you have used it
Yeah i was looking at this then was looking at a norbar too...This one just makes it if you are still struggling. It just short of the recommended torque or you could do 200nm plus 180 degrees. I have two of the smaller Teng wrenches and they are nice.
1992 3b S2 CoupeComment
You only need a bit of maths and common sense. My 70kg weight on the end of a 600mm breaker bar ~ 400nm
F=MA
70 x 9.81 = 686n
x 0.60m = 412nm
Incidentally I’d say 200 + 180deg is a lot more than 400nm on this bolt.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
I've always used the 200Nm + 180 degrees, but have never managed to get the full 180 degrees even with a long length of scaffold bar. You can get 200Nm + 90 degrees and then it gets very tight. I've never had one work loose with this method and replace the bolt each time. You will require a 3/4" socket and breaker bar. 1/2" will shear easily doing this bolt up.91 Modded 3B
14 A6 Avant Black EditionComment
Why not get a number of people together to chip in and buy it ? And then just use it when you need it amongst themselves? Obviously you will need to pay postage whenever the next person wants to use it ? I'd be happy to contribute. I know on other forums where a guy rents out specialist tools with a full holding deposit.Comment
Personally I've got a 1inch breaker and matching 27mm socket. I got 200nm on easily and could not get 180 degrees on.
My car was moving on the axle stands.. Never had one work loose..Comment
This
I only managed 90 degrees after the 200nm (I weigh 70kg too) and it was ****ing tight. No need for any more IMO
David, I have a 27mm socket and 3/4 inch breaker bar if you want to borrow them...
The Perfectionist
Thanks folks...i am north of 70kgs so thats not the issue
I remember just how much of a non event it was getting the desired torque with the right tool and wanted to achieve it that way again.
