Hi, does anyone have a big torque wrench i could borrow to do the cambelt?
Torque wrench
This one just makes it if you are still struggling. It just short of the recommended torque or you could do 200nm plus 180 degrees. I have two of the smaller Teng wrenches and they are nice.
https://www.screwfix.com/p/teng-tool...3-4-x-33/58074
I was thinking of getting one of these. If you can't borrow one I might be interested it buying it from you after you have used itNothelle S2 Avant
Originally posted by Tractor Dave View PostThis one just makes it if you are still struggling. It just short of the recommended torque or you could do 200nm plus 180 degrees. I have two of the smaller Teng wrenches and they are nice.
I was thinking of getting one of these. If you can't borrow one I might be interested it buying it from you after you have used itsigpic
1992 3b S2 Coupe
You only need a bit of maths and common sense. My 70kg weight on the end of a 600mm breaker bar ~ 400nm
F=MA
70 x 9.81 = 686n
x 0.60m = 412nm
Incidentally I’d say 200 + 180deg is a lot more than 400nm on this bolt.Panthero Coupé quattro 20vt
I've always used the 200Nm + 180 degrees, but have never managed to get the full 180 degrees even with a long length of scaffold bar. You can get 200Nm + 90 degrees and then it gets very tight. I've never had one work loose with this method and replace the bolt each time. You will require a 3/4" socket and breaker bar. 1/2" will shear easily doing this bolt up.91 Modded 3B
14 A6 Avant Black Edition
Why not get a number of people together to chip in and buy it ? And then just use it when you need it amongst themselves? Obviously you will need to pay postage whenever the next person wants to use it ? I'd be happy to contribute. I know on other forums where a guy rents out specialist tools with a full holding deposit.
Originally posted by Monkeymagic View PostPersonally I've got a 1inch breaker and matching 27mm socket. I got 200nm on easily and could not get 180 degrees on.
My car was moving on the axle stands.. Never had one work loose..
I only managed 90 degrees after the 200nm (I weigh 70kg too) and it was ****ing tight. No need for any more IMO
David, I have a 27mm socket and 3/4 inch breaker bar if you want to borrow them...
The Perfectionist
